Old 08-26-2012, 12:13 PM   #1
21ss roo 30 amp pedestal tripping
Help, when running AC the 30 amp shore power trips. . The only thing running is hot water heater. Thanks
shawndfr is offline   Reply With Quote
Old 08-26-2012, 12:15 PM   #2
DF5.4's Avatar
Can you reach a different pedestal and see if that one trips?
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 08-26-2012, 01:10 PM   #3
Triguy's Avatar
A couple of questions. Just to clarify, you are saying the pedestal breaker is tripping, right? Or are you referring to the Roo's main breaker or the air conditioner branch circuit breaker? Also, besides the AC and HWH, were you also running the fridge on electric along with the converter (charging the batteries)?
If its the park pedestal, I suspect low voltage. You can (and should) check for this before plugging in anyway. Do you have a voltmeter handy?
You could try running the HWH and fridge on propane and see how the AC works with that.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-26-2012, 02:49 PM   #4
sherdep's Avatar
if it is the Park's Pedestal breaker - could be a faulty or weak breaker also
How many volts were at the pedestal before plugging in?
I have a handy plug in meter that tells me how many volts are at the pedestal and if it is wired wrong or not - comes in very handy before blowing up the camper.
I have had this a few times and the way I fixed it was with a 50 amp to 30 amp - the breaker never popped and the cable wasnt getting warm either.
If it is the Main breaker in the trailer - it means you have too many things running and drawing over 30 amps.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 08-26-2012, 03:57 PM   #5
Herk7769's Avatar
If the pedestal voltage is less than 110 volts, your camper will draw WAY more than 30 amps running the water heater and air conditioner at the same time.
Watts = Volts x Amps. Low volts means high amps to do the same work.
Turn off your electric water heater element and use propane.
HAM CALLSIGN - KC3FFW
Old 08-26-2012, 08:29 PM   #6
caper's Avatar
Amp draw
AC 12 - 16
WH 9 - 12
REEFER 5 - 8
CON. 1 - 8
if you are at the low end of all 4 you are drawing 27 amps the high end you are are at 45 amps. This is the reason you tripped the breaker at the post. If it was a hot day and most of the TT were running their AC then you most likely had a voltage drop at the post. By putting your WH on to propane you will be dropping your amp usage by a min of 9 amps.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
