21SS Water System questions
Purchased a barely-used 2013 21SS a few weeks ago. The previous owners left all the owner's manuals, etc. in them, but they don't seem to be very specific about a lot of things. (Found out most of what I know from a series of Roo walk-through videos on YouTube.) One question about the water system - one of the manuals showed the 3 valves on the water system near the hot water heater. It said that all 3 valves should be parallel/in-line with the hoses for the system to be completely open. To bypass the hot water heater, the valves should all be perpendicular/crossways to the line. When I looked at the valves, the top & bottom ones are turned in-line with the hoses, but the middle one is crossways. However, the kitchen & bathroom faucets all worked as did the shower, and all three had both hot and cold water. The only thing I noticed was that there seemed to be very little water pressure in the bathroom sink faucets. Is this system different from what is described in the manual? Should I leave the middle valve as is or turn it in-line as the others? (I was going to try it during the weekend but since everything was working I was hesitant to do so.)
