Old 04-05-2012, 01:14 PM   #1
cogito ergo moo
Cowracer's Avatar
21SSL hitch height?
Hey all.
I am expecting my new 21SSL off the line on the 23rd. I am ordering a W/D hitch, but I need to know hitch height of the unit (when level) so I can get the correct shank.
If any of you have one of these units (or maybe even a 21SS), could I talk you into measuring how far it is from the ground to the top of the hitch-ball socket while the trailer is sitting level?
That would sure help me a lot!
Thanks!
Tim
Cowracer is offline   Reply With Quote
Old 04-05-2012, 02:05 PM   #2
Triguy's Avatar
Hi Tim,
I'm sure someone here can measure their's for you.
Just in case you don't get any owners replying to this specific post I suggest that you do a search for those two models and PM their owners.
Also, your dealer might have one on their lot they can measure for you.
Good luck!
By the way - Nice trailer. What do you plan to haul on the front deck?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-05-2012, 09:29 PM   #3
cogito ergo moo
Cowracer's Avatar
honda rancher and arctic cat 350 4x4. or my Harley Street Glide. Actually the front deck will probably be empty a good portion of the time. It was only a grand or so more than the standard 21ss, and I figured better to have and not need than to need and not have.
Also, my TV is a Ford Excursion. I will use the deck to carry all the junk most people carry in the back of their pickups. Charcoal, propane, firewood, etc... that I dont want rattling around in the back of my exy.
Tim
Old 04-06-2012, 06:44 AM   #4
kingranch's Avatar
Part of the walk through the dealer sets up the hitch for you I have a 21ss and 2003 f150 king ranch crewcab so I have a real close setup to you mine is 22.25 " I also use a w.d. And friction sway on my setup so I hope this helps
kingranch is offline   Reply With Quote
Old 04-06-2012, 06:52 AM   #5
Triguy's Avatar
Tim
Lots of nice toys to haul . Should be perfect for you.
Scott
2012 Shamrock 233S
Old 04-06-2012, 09:19 AM   #6
cogito ergo moo
Cowracer's Avatar
Thanks. I am getting my hitch separately so the dealer will be no help. My big problem is getting a hitch with enough drop. The Excursion is lifted 8 inches on 37" tires. If the top of the hitch socket is 22 1/4 then I'll be alright.
Below is a pic of the Big Unit (my Excursion) with my old pop up
Tim
21ssl
