Old 03-08-2015, 12:39 PM   #21
fonzie's Avatar
I think he only has one slide as per web site. Also see post #11.
233s owners. Slide out question
Fonzie
Old 03-08-2015, 12:45 PM   #22
geotex1's Avatar
Oh, I see. I stand completely corrected! When reading through the thread, I got attached to the owner with the 23IKSS, which has both slides, and what I kept referencing.
My apologies Eric F. and fonzie for not re-reading the original question before answering!
The 233s is a single through-frame slide. You don't need to cut the motor wires, just unhook the battery and shore power.
geotex1 is offline   Reply With Quote
Old 03-08-2015, 12:47 PM   #23
fonzie's Avatar
Originally Posted by geotex1 View Post
Oh, I see. I stand completely corrected! When reading through the thread, I got attached to the owner with the 23IKSS, which has both slide, and what I kept referencing.
My apologies Eric F. and fonzie for not re-reading the question before answering!
Fonzie
Old 03-08-2015, 01:23 PM   #24
Eric F.'s Avatar
That's what I thought. I saw no reason to cut anything if the battery was already dead.
Eric F.
2015 Flagstaff Shamrock 233S
2012 Ford F250
Eric F. is offline   Reply With Quote
Old 03-11-2015, 02:43 PM   #25
Take The Road Less Travld
MuddauberE's Avatar
This is good to know!
thanks
"Take The Road Less Traveled"
2013 Rockwood Roo 233s
2017 Ford F-150 EB
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
Old 03-17-2015, 10:41 AM   #26
Okay, I am a little confused by all this. I do not have a 233ss but a 23SS. The slide fuse is not a resettable one. It has blown once, and all I did was use the crank on the fixture under the couch to crank the slide out. So what is all the talk about not being on shore power or using a battery disconnect, why not just pull the fuse? I plan on changing mine to a resettable one in the near future since it is under the trailer and the not the nicest place to get to.
2008 F150 v8 5.4
2015Rockwood Roo 23SS
2015 Nights Camping: 39
2016 Reserved: 23
Davylee is offline   Reply With Quote
Old 03-17-2015, 04:12 PM   #27
Eric F.'s Avatar
Pulling the fuse will work as well. During my original walk through of my TT the technician said I needed to cut the wires to the slide motor if I ever lost power or the slide stopped working in order to retract it manually. I thought he didn't know what he was taking about and I was right!
Eric F.
2012 Ford F250
Old 03-18-2015, 09:26 PM   #28
Stormrider151's Avatar
I had a 2012 23ss. The slide failed the day I brought it home.. All I did was crank the slide in using the connecter under the sofa. The fuse located on the tongue had blown. The dealer sent a tech to the house and he replaced the fuse with a self resetting breaker. Never had a problem after that.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 03-22-2015, 08:23 PM   #29
According to the documentation provided with my trailer from Flagstaff there is no mention of having to disconnect any wiring when manually operating the dinette slide. Whether the battery is dead or not the motor is still isolated from the power source buy the switch. As long as the switch is not being activated while manually operating the slide there should not be an issue.
Gregg, Karen and Devin
2013 Shamrock 23IKSS
2012 F150 FX4 5.0L
Engauge is offline   Reply With Quote
233, 233s, slide, slide out
