09-26-2013, 09:10 PM
#21
Originally Posted by TK421
The camper is closed up but I took a few pictures to give you an idea what the bins look like and what bins we use.
Thanks for the pics! Looks like I'm going to Wal-Mart...
09-26-2013, 09:13 PM
#22
X2 on the pics thanks
10-10-2013, 09:41 AM
#23
It's getting to that heater season! As a new owner of a 233s, a question I have is, is the furnace just propane or is it electric as well? Just curious because I couldn't find it in the manual anywhere and I will be taking it out for the first time before I winterize it at the end of October. Thanks.
10-10-2013, 10:05 AM
#24
Striclty fueled by propane, but you need 12V power as well for the controls and CO detector.
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
10-10-2013, 10:19 AM
#25
Always Learning
(Sorry, I don't know this camper nor much about furnaces..) BUT- doesn't it have a fan on it to blow the hot air into the unit? Would that fan be electric?
10-10-2013, 10:32 AM
#26
Yes - should have said 12v for controls & fan...
But its not like the fridge, where you could run exclusively on electric. The heat only comes from propane.
10-10-2013, 10:38 AM
#27
Always Learning
Oh, right- of course. I didn't think of it that way.
And, sadly- I know that one all too well. I've ran out of propane twice before I finally wised up to reading my changeover. Once (in FLORIDA of all places) I had to go to the gas station and buy a regular 18lb tank to get through until the propane filling station opened.
10-10-2013, 10:40 AM
#28
Ok. Thank you. I should be all set to go then.
10-10-2013, 11:44 AM
#29
Campman, be aware that if you are dry camping or boondocking, the furnace is the trailer's biggest power hog on the its battery.
that's why most of us dry campers/boondockers have at least two deep cycle batteries, along with a generator or solar system.
you'll run out of battery power way before you run out of propane.
if you have hookups, most of us use an ceramic heater to run and allow the trailer's furnace to supplement the ceramic heater.
10-10-2013, 01:11 PM
#30
Originally Posted by bikendan
Campman, be aware that if you are dry camping or boondocking, the furnace is the trailer's biggest power hog on the its battery. that's why most of us dry campers/boondockers have at least two deep cycle batteries, along with a generator or solar system. you'll run out of battery power way before you run out of propane. if you have hookups, most of us use an ceramic heater to run and allow the trailer's furnace to supplement the ceramic heater.
Thanks for the ceramic heater tip! I'm leaving tomorrow for the maiden voyage with my 233s and it promises to be cool in PA.
Might save some propane with this tip.
10-10-2013, 01:17 PM
#31
FourWheelers, make sure the heater has a tipover cutoff safety switch.
10-10-2013, 01:39 PM
#32
Nofitpitchin: Heading out to get that table cart you showed us. Thanks again.
Bikendad: Safety first of course. Made sure the tip over protection was there.
10-10-2013, 02:12 PM
#33
I'll definitely look into the ceramic heater. I'm from PA and the nights get chilly this time of year but it doesn't stop us from camping.
10-10-2013, 03:03 PM
#34
We are heading out to Hickory Oaks Campground in the Lancaster area. Not only do I have the Nor easter to deal with but the temps should be chilly.
10-10-2013, 03:29 PM
#35
Take The Road Less Travld
Speaking of propane and power heating, I wanted to make sure you knew that the water heater has a switch located in the outside access for propane or electric heating.
10-10-2013, 04:57 PM
#36
I found that switch after I bought the camper. The previous owner told me it needed to stay " on " to use propane or turn it " off " to use electric. He also didn't know why the electric heater never worked that well.
I promptly turned it off, then replaced the heating element and zinc.
10-17-2013, 03:35 PM
#37
Thought I'd chime in here. We had our 233S out this past weekend with temps dropping into the low 30's. I used 2 of the small ceramic heaters and the furnace only ran a couple of times. Good thing too as I found we were almost out of propane when we got home!
Comfort wise, we served breakfast for ourselves and the other family we were camping with. 4 Adults and 5 kids, all at one time, very comfortably!
Mark, Jenny, Adam & Lucy
2013 Rockwood Roo 233S
2015.5 Silverado 2500HD CCSB with Duramax/Allison
10-20-2013, 08:09 PM
#38
Originally Posted by BeagleIL
Thought I'd chime in here. We had our 233S out this past weekend with temps dropping into the low 30's. I used 2 of the small ceramic heaters and the furnace only ran a couple of times. Good thing too as I found we were almost out of propane when we got home! Comfort wise, we served breakfast for ourselves and the other family we were camping with. 4 Adults and 5 kids, all at one time, very comfortably!
I will be taking mine out in the middle if November. I'll winterized it this week because of the lowering temperatures but won't stop the trip from happening. I want to see how comfortable we are when it cooler out anyway. Glad to hear you were warm.
"Take The Road Less Traveled"
2020 Cherokee 294BH
2021 Chevy Silverado 2500HD 6.6 Duramax Diesel
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
10-20-2013, 08:58 PM
#39
My biggest problem was that 2 ceramic heaters and 3 mattresses were popping the breaker inside the camper. So the second night I snaked an extension cord in from the site pedestal for the second ceramic. I will definitely be adding a second outlet on the hot water heater circuit as we never run it on electric. I can easily tap in and have an outlet right there below the sofa. Hard to believe they ran all 7 outlets on one 15 amp breaker.
10-21-2013, 07:22 AM
#40
11' Dodge Ram 3500 DRW 6.7 Cummins
12' Rockwood Roo 233S
Current: AZ
Wife: NY
Me: IL
3 Akitas (RIP D-Dog)
