Old 07-13-2015, 06:22 PM   #1
23IKSS Water Leak While Towing
We purchased a new 2015 23IKSS this spring. Friends of ours purchased the same model. We both towed our campers through a rainstorm over the forth of July weekend. When we arrived and opened the slide, both of our campers had a puddle of water on the floor near the dinnette. Water appears to be finding its way in around the bottom slide seal over the roadside tires. I have an appointment at our dealer's service department next week.
Anyone else having a similar issue? Given the fact it happened to both campers this could be a design/manufdacturing defect.
mbabineau is offline   Reply With Quote
Old 07-14-2015, 10:51 PM   #2
It appears others have had this problem - posted on a recent thread. We'll need to understand this before we commit. We like this model but will need to be fully assured that it won't happen for us.
drhroo is offline   Reply With Quote
Old 07-14-2015, 11:12 PM   #3
KMP44's Avatar
Got any pictures of the area where it leaked? We've towed ours in countless rain storms - never any leaks. Curious what the bottom seal looks like.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 07-16-2015, 02:11 AM   #4
ficksters's Avatar
23ikss owner here who has talked extensively to the dealer. Most likely it is coming from the kitchen slide since it doesn't lower down like the dinette and couch slide does. Look on the side of the kitchen slide and you will see the track that moves the slide in and out. Water can come in the channel above the zig zag track or on the zig zag track. That's what was communicated to me by the dealer and supposedly it's a known deal on the ikss because of the kitchen slide.
2014 Shamrock 23IKSS
2007 Chevy Tahoe 5.3L V8 with 3.73 rear end, Primus IQ Break Controller, and Equalizer Hitch
DW (Not allowed to say)
DD (3 year)
DS (6 months)
ficksters is offline   Reply With Quote
Old 07-16-2015, 05:21 AM   #5
Known deal meaning something they can fix or meaning that we're stuck with it? Is it something they will fix in the new models? (Just hoping that they would have offered a bit more insight on a fix.)
Old 07-16-2015, 08:16 AM   #6
KMP44's Avatar
While driving with the slide closed? The entire track would be inside the trailer at that point.
2017 F-250
Old 07-16-2015, 08:54 AM   #7
RooVader's Avatar
Yeah I am confused as to what the track would have to do with anything unless you mean pulling it in while raining. I have done that a dozen times with the same type of slide and have not seen any issues and I see these types of slides everywhere on various campers.
Could it have something to do with the proximity of the slide to the wheels and maybe wheels spinning water up underneath? Maybe if that seal isn't tight it would perpetually shoot water at the seal? My slide is more in front of the wheels but I sure haven't seen this and I have been towing in a ton of rain.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
Old 07-16-2015, 12:02 PM   #8
I should have been more specific. The leak is on the dinnette/sofa slide. The water was discovered once we arrived at our destination after towing through a rainstorm. When we opened the dinnette/sofa slide there was a puddle of water on the floor by the dinnette. The carpet was also wet. This area is directly over the tires. The bottom seal for this slide attached to the coach and wipes the bottom of the slide unit. When the slide is out, the seal make a tight fit to the slide because the slide drops down when its fully extended. When it's brought all the way in it raises above the floor. The bottom seal at this point is barely making contact with the slide and in fact over the tires it doesn't appear to be touching the slide at all. Our friends bought their Roo at the same time, same model, same year (2015)and had the exact same problem. Water flying off the tires at 60 mph will find its way over this seal. I have not noticed any problem with the kitchen slide which is a completely different design.
If older model years do not have this problem I wondering if there wasn't a design or materials change.
It's going back to the dealer on Monday. I'll post any updates!
Old 07-16-2015, 12:49 PM   #9
RooVader's Avatar
Ohhh, gotcha! That makes more sense. I would think the 23ss or any super slide models would have this same issue. I am just surprised it hasn't come up more often but your explanation makes a lot of sense. Thanks!
2013 F150 FX4 EB
Old 07-16-2015, 02:11 PM   #10
KMP44's Avatar
Picture of your bottom seal??
2017 F-250
leak, towing, water, water leak
