Old 05-15-2014, 06:29 PM   #11
Tewksburyduck's Avatar
After physically looking and looking at the wiring diagram for the Genesis GT-2.0 I don't think there is a second fuse behind the unit. I will call the dealer tomorrow. Thanks for your support. That's what makes this forum so invaluable.
Tewksburyduck
2013 Rockwood Roo 23SS
2013 Jeep Grand Cherokee Limited
5.7-liter Hemi V-8
2015 nights camped - 5
Tewksburyduck is offline   Reply With Quote
Old 05-15-2014, 06:43 PM   #12
Rrickim63's Avatar
The best way to see if the radio has power is to pull it and use a multimeter to verify voltage and ground. Some radios may have 2 wires for power
1999 Silverado with tow package
2006 Roo 23B hybrid
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 05-15-2014, 07:04 PM   #13
KyDan's Avatar
Originally Posted by Tewksburyduck View Post
The blade fuse behind the radio looks good. I have not seen an inline fuse. I will look now though.
Test with a meter. Some look ok but aren't.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 05-20-2014, 06:29 PM   #14
I bought a Genesis 2.0 replacement unit on Ebay for $59 + $14 shipping. It was being sold as an overstock item and was described in the add as used. I contacted the seller to make sure I could return it if it wasn't fully functional. I installed it this evening and everything works as it should. I hope everyone can get out this weekend. We are heading to Terrace Pines in Ossipee, NH.
Tewksburyduck
5.7-liter Hemi V-8
Old 05-23-2014, 06:59 AM   #15
Dave Lyon's Avatar
I blew the two 40 amp fuses at the inverter by hooking up the battery cables in reverse. I have not replaced the fuses yet. Now, when hooked up to shore power I do not get sound through my speakers with power the genesis radio. Also, the DVD player will not insert a disc. I will find replacement fuses but I'm wondering if the radio needs those fuses to fully function. I did pull the radio from the wall and the fuse there is not blown.
There was an identical thread last week on this subject - my buddy did the exact same thing with the same model trailer 2 weeks ago and he replaced the two 40A fuses and there was an inline fuse in the Genesis unit that was blown. Once replaced, he was good to go.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 05-26-2014, 06:04 PM   #16
Thanks. I did check and replace the inline fuse with no luck. The fact that the disc player wouldn't accept a disc I assumed it was fried. The replacement from ebay did the trick.
Tewksburyduck
5.7-liter Hemi V-8
fuse, inverter
