Old 05-14-2014, 07:55 PM   #1
Tewksburyduck's Avatar
40 amp fuses at inverter
I blew the two 40 amp fuses at the inverter by hooking up the battery cables in reverse. I have not replaced the fuses yet. Now, when hooked up to shore power I do not get sound through my speakers with power the genesis radio. Also, the DVD player will not insert a disc. I will find replacement fuses but I'm wondering if the radio needs those fuses to fully function. I did pull the radio from the wall and the fuse there is not blown.
Tewksburyduck
2013 Rockwood Roo 23SS
2013 Jeep Grand Cherokee Limited
5.7-liter Hemi V-8
2015 nights camped - 5
Tewksburyduck is offline   Reply With Quote
Old 05-14-2014, 07:57 PM   #2
markb5900's Avatar
The radio operates off the 12V, so you do need those fuses for it to run
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 05-14-2014, 10:25 PM   #3
bikendan's Avatar
Tewks, just to clarify, it's the CONVERTER, not the inverter.
and since those fuses are from the battery and the radio is 12v, then it may need them to work.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-14-2014, 11:03 PM   #4
TURBS's Avatar
Check for a fuse holder behind the radio.
Dont ask me how I know.
Ps you'll have to pull the radio.
TURBS
Sabre owners united!
Old 05-15-2014, 05:29 PM   #5
Replaced the 40 amp fuses and still no sound from speakers when set to on position. Also will not accept a DVD. Any suggestions? The fuse behind the radio looks fine.
Tewksburyduck
5.7-liter Hemi V-8
Old 05-15-2014, 05:32 PM   #6
bikendan's Avatar
does your other 12v stuff work(lights, water pump, furnace), without being hooked to shore power?
Old 05-15-2014, 05:37 PM   #7
If the radio is turning on, ie the display is lighting up, but you get no sound you may have damaged the radio. The fuses will protect the wires and such from overheating but they don't react fast enough to stop the radio from being damaged from the reverse hook up, DC electronics don't like to be hooked up backwards.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 05-15-2014, 05:39 PM   #8
Furnace, lights, and water pump work while on battery power only.
Tewksburyduck
5.7-liter Hemi V-8
Old 05-15-2014, 05:58 PM   #9
Herk7769's Avatar
It does not take much reverse current to fry a computer. Sounds like it could be damaged. Did you check both fuses in the radio? There is one that supplies "full time" power (clock, panel lights, etc) and one that supplies "part time" power (all the rest - like DVD player).
The full time power is an inline fuse and the part time power is a "blade type" in the back of the radio.
You may need to meter them for continuity since they can fail at the solder joint and the open may not be visible.
HAM CALLSIGN - KC3FFW
Old 05-15-2014, 06:08 PM   #10
The blade fuse behind the radio looks good. I have not seen an inline fuse. I will look now though.
Tewksburyduck
5.7-liter Hemi V-8
fuse, inverter
