10-24-2016, 11:20 AM
6 Volt batteries on the front of my 23IKS
Is there enough room to mount 2 Trojan T-105 batteries in place of the 1 - 12 volt battery on the frame of the 23IKS? It looks close but would like to here from someone who has don it.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
10-24-2016, 11:25 AM
I can't answer your question directly, however I recently purchased this battery box, designed specifically for your needs (I'm doing the same thing). Below are the dimensions:
http://www.allbatterysalesandservice...cfm/4,573.html
10-24-2016, 11:27 AM
I am guessing your Rockwood has the same amount of space as my Solaire. I mounted an aluminum battery box from Torklift on top of the frame rails where the factory battery sat. It has room for 4 batteries but I only put 2 in it. My inverter and solar charge controller are on the other side of the box. It gives some level of security because it is lockable and secured to the frame. 2 brand new Trojans might look tempting to thieves.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
10-24-2016, 11:50 AM
If you have room for two standard Group 24 12v batteries, then the 6 volts should fit.
They are taller than the Group 24 battery.
10-24-2016, 01:33 PM
I prefer 12v group 27 battery`s .
I bought 3 battery and 3 box and 2 marine 3 ways switch.
Easier to recharge plus I interconnect with solar panel and inverter with the switch.
I also use a 2000 watt inverter generator.
I made a aluminium open rack behind the propane tank.
Less expensive deal.
I never run out of power.
I have a circuit diagram if interested.
10-24-2016, 02:46 PM
6 volt batteries
I suspect the tongue on our rigs are similar. Recently placed a pair of 6 volt batteries on the rails of my Roo 17 without problems, but the space is tight. Going to check out the capacity this weekend with a couple of cold nights in Big Meadow Skyline Drive.
10-24-2016, 02:50 PM
The OP has a hybrid TT.
Do you have a TT, cause unless you do some extensive modification, you aren't going to have room for three Group 27 batteries on a typical TT A-frame.
I'm guessing that you have a motorhome or 5th wheel, to be able to fit 3 Group 27 batteries.
10-24-2016, 04:25 PM
Yes.
This is the box I installed on the existing angle iron - no modifications required (for our 2013 IKSS). Now, if you plan to use 12V, this box isn't tall enough. It is wide enough. I ended up using two 12V Gr 24 Trojan batteries because of the box height. But the existing spot on the frame is wide enough. I would have gone with the 6's, but very happy with these so far.
23" Aluminum Battery Lock Box — Rvlockbox.com
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
10-24-2016, 11:20 PM
Yes , I have a HTT and my home made rack is located at the whide section of the V frame behind the propane tank.
10-24-2016, 11:44 PM
As requested here the diagram for the battery`s
10-24-2016, 11:48 PM
As requested here the diagram for the 3 battery`s.
10-25-2016, 05:57 AM
what HTT do you have?
please post pics of your battery setup.
10-25-2016, 10:43 AM
Torklift also makes a locking solar battery box to fit two 6V batteries (even though mine is only holding a single puny group 24 at the moment).
See my installation at http://www.restcure.ca/mods_battbox.html
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
10-25-2016, 10:44 AM
Duplicate post
10-25-2016, 11:28 AM
My HTT is winterize right now but I am sending you 2 pictures of my rack with 3 battery`s setup, not very clear, sorry!
