Old 08-30-2016, 03:40 PM   #21
Turbs is closest to what my problem "may" have been. I ended up taking it to the dealer, and they said there were areas of air leaking back and forth. I think this plus a combination of me running the ac on low when it was Uber-humid caused my problem. Time will only tell.
It's probably not going to get a real test until next summer....off warranty no less, wish me luck
Sent from my SM-G900P using Tapatalk
jehrbear is offline   Reply With Quote
Old 08-30-2016, 03:58 PM   #22
Hugeez's Avatar
A/C freezing up is usually caused by 1 of 2 things. Insufficient airflow across the evaporator or low refrigerant.
2015 Puma 29RBKS
2013 Ram 1500 5.7 Hemi 4X4
E2 WDH 10000lbs Air Lift Rear Helper Springs
Troy, Josie and our 2 K9 co-pilots Breck and Maggie
USN 86-92
Hugeez is offline   Reply With Quote
Old 08-31-2016, 03:46 PM   #23
Freeze up is not normal. You have low coolant gas. And...SOME Dometic units do have a port for recharging. (I don't know about others) The issue is why do you have low coolant? There must be a leak because it does not evaporate on its own. They do make a sealer for RV units, but it is very very expensive.....But it will work to seal any pinholes you may have. If you are under warranty take it in now.
Good Luck!
David 01 is offline   Reply With Quote
Old 08-31-2016, 04:12 PM   #24
Head Rambler
You don't necessarily have to have low refrigerant in these units to have them freeze up. It's very easy to get these units to freeze up by affecting the air flow through them or increasing the humidity to the point that the unit can't shed it from the evaporator coils. That's why they have freeze coils on them. Because the mfg's know that it's going to happen.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
