Old 07-28-2016, 09:54 AM   #1
AC freezing up-Normal? or Issue.
Couple times in our 2015 Roo 19 we've had the AC freeze up on us. The fan seems to run at about 60% and it's luke warm air. I've flipped it over to fan high, and a few minutes later water/condensation pours down the gutters like a river. I'm wondering if this is normal and expected, or I should run it in for a warranty repair.
Couple of factors that make me wonder if this is "to be expected":
We've been camping with outside temps in the 90-100 range with high humidity (Missouri, Arkansas, with Colorado being the lowest humidity ranges).
We've had 3 events recently where the AC froze up. Once through the night, and twice when we left the unit running on low during the day.
What's your experience? Lots of info on this condition, just wondering about the hybrid/Roo/Shamrocks specifically.
jehrbear is offline   Reply With Quote
Old 07-28-2016, 10:19 AM   #2
MiCamper6's Avatar
Have you had your fan on high?
MiCamper6 is offline   Reply With Quote
Old 07-28-2016, 10:24 AM   #3
Taranwanderer's Avatar
Sounds like you might be low on refrigerant. I'd have it checked.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 07-28-2016, 10:29 AM   #4
GalsofEscape's Avatar
Well, so far we have camped once in 100 degree very humid conditions, we did not have this problem.... but we were in shade and I do have the gizmos on the tent ends. The AC cycled on and off and kept the camper at a reasonable temperature. When the AC ran, there was a steady stream of condensate coming off the roof. Will see how it handles at the beach in a couple of weeks......
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
Traveled 19520 miles and 209 nights in 7 years and counting
GalsofEscape is offline   Reply With Quote
Old 07-28-2016, 10:30 AM   #5
Condensate off the roof is fine, normal. Freezing up though, is not.😉
Old 07-28-2016, 10:33 AM   #6
Flybob's Avatar
Run on high fan until the temp and humidity are reduced, then you should be able to run on auto. Check the filter and clean if necessary. If the AC is mechanically OK it can freeze up in very humid conditions if there is not enough air flow to keep the condensate above freezing on the coils.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-28-2016, 10:34 AM   #7
It is Normal
I have a 2015 Shamrock 19, and you need to run the AC on High Cool all the time or the unit will freeze up, especially if there is a lot of outside humidity. I do not know the exact reason this occurs but I thought mine was broken and took it back for service and they told me this is recommended by manufacturer when humidity is greater than 45%. I live in NC and run it on high whenever we camp (seriously humid) and have not had a problem since. Just adjust the temp gauge to suit your needs. I was out last week and it was 98 with a heat index of 105, and was very comfortable. Hope this helps.
bkc19922 is offline   Reply With Quote
Old 07-28-2016, 10:36 AM   #8
I know you asked specifically about experiences from hybrid/Roo owners but I will tell you.. ANY R/V air conditioning is susceptible to freezing up in high humidity conditions running the fan on low only. The more air flow the better for keeping it from freezing.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 07-28-2016, 10:37 AM   #9
AquaMan's Avatar
With the fan on low and high humidity, you may not be moving enough air across the coils to defrost. When I had one AC in my precious 5er, it could not keep up in 95 degrees and high humidity and would freeze up. When I added the second AC it gave each unit a break in order to defrost. I'm guessing your unit is just being overworked in the high temps and humidity.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
AquaMan is online now   Reply With Quote
Old 07-28-2016, 11:18 AM   #10
Head Rambler
Along with the suggestions above, remove the grill and check to see if the freeze coil (looks like a stack of quarters with wires) is attached to the bottom of the evaporator coils.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
