Old 06-13-2016, 01:58 PM   #1
AC power
2014 Shamrock 213KSS. Out camping this weekend, no issues until Monday AM, no AC inside camper (AC, microwave, outlets). 110 going to breaker panel, and each breaker, but nothing past the breaker panel. DC fuses all good. Any suggestions
The Happy Campers
Gary
Erin (the wife)
Nick (the dog)
and sometimes the M-I-L
Reynolds551 is offline   Reply With Quote
Old 06-13-2016, 02:09 PM   #2
jtstromsburg's Avatar
So you've Checked for 110v at panel in your camper and have it there, but not coming out?
Gotta be 30 amp main in that panel then.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 06-13-2016, 03:12 PM   #3
there's a main breaker an there are other breakers in line with the main, AC, microwave and the wall outlets. the main is working when I turn it on and off. the other breakers work. now I'm checking from green ground to the black wire on the breaker.
The Happy Campers
Gary
Erin (the wife)
Nick (the dog)
Old 06-13-2016, 03:22 PM   #4
Head Rambler
When checking for voltage, are you checking between hot and the ground bar or between hot and the neutral (white wires) bar?
Gotta go campin!
Old 06-13-2016, 03:26 PM   #5
Bluepill's Avatar
Your outlets are usually protected by a GFCI. Usually one GFCI outlet feeds other "standard" outlets "downstream", so when the GFCI trips, the other outlets go dead.
http://www.electrical101.com/gfci-line-load-wiring.html
It is unusual to have the A/C on a GFCI circuit, but not impossible. The thermostat for your A/C may be run off of 12 volts DC. Check the manual for that info.
2008 Itasca Meridian 37H
Old 06-13-2016, 03:28 PM   #6
Iwannacamp's Avatar
Unless I am reading something into this...maybe the 30amp(main) was tripped.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 06-14-2016, 01:34 PM   #7
hay campers back again. the no power issue. the breakers never tripped, we were using a one cup coffee maker. We made one cup then we tried to make a second cup and the power went out. there is 120 at all the black breaker wires, checking from the green ground wire.
The Happy Campers
Gary
Erin (the wife)
Nick (the dog)
Old 06-14-2016, 03:09 PM   #8
Head Rambler
That leads me to believe you have a neutral issue. Did you check the voltage between black and white?
Are you sure you didn't trip a GFCI receptacle somewhere?
Gotta go campin!
Old 06-14-2016, 03:33 PM   #9
hay Bama Rambler: the only GFCI is in the bath room. that was not tripped. that's what I don't get not one of the breakers tripped. There is 120 from the ground to the neutral, I will go out right now and check voltage between black and white.
The Happy Campers
Gary
Erin (the wife)
Nick (the dog)
Old 06-14-2016, 03:47 PM   #10
Try plugging something else in. Maybe your coffee maker is shot.
2011 Traverse LT, 3.6L, FWD
power
