Old 04-27-2016, 07:38 PM   #1
Dawg Fan
AC question
Dometic ac fan will not come on in the auto position. The compressor will come on but no fan. The fan will only work in the on position. Any thoughts?
2009 Rockwood Roo 21ss
Ham Bone is offline   Reply With Quote
Old 04-28-2016, 11:52 AM   #2
Head Rambler
It would help to know the model of the A/C and also the type thermostat you have.
Having said that, you probably have an analog t-stat. Try removing the cover and jumping a wire between the green wire and the fan terminal. If the fan runs then it's most likely a bad t-stat.
Gotta go campin!
Old 04-28-2016, 06:15 PM   #3
And if it is a bad T-stat, install a digital and you'll be much happier with the way it holds the temperature.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
