Old 11-10-2015, 07:07 PM   #1
Actual shamrock 19 weight
We are considering a slightly larger HTT. Weight listed at 3775lbs with CCC of 1100lbs. We use a 2007 4runner 4.0L V6 as tow vehicle. It works great. I have seen the unloaded weight of our 2006 Shamrock listed between 3174 to 3775lbs. CCC listed between 1000 and 1400lbs. If the lower numbers are correct I'm not sure I want to go bigger. We live in the Blue Ridge Mountains and camp mostly in the Smokys so staying well below the weight rating on our 4runner is important.
jrctoby is offline   Reply With Quote
Old 11-10-2015, 09:02 PM   #2
Moderators' Assistant
bikendan's Avatar
Actual weight will be on yellow sticker, on outside of trailer or in door frame.
Actual weight will vary, depending on options.
Our 23SS weighed 400lbs. more than its brochure/website dry weight, from the factory.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 11-11-2015, 02:51 PM   #3
Shamrock GVWR
So I guess the GVWR is the constant. The yellow label is not legible anymore but there is another label below it that says the maximum cargo weight can not exceed 1114 lbs. So can I figure the dry weight by subtracting the CCC from the GVWR?
shamrock, weight
