Old 11-25-2011, 09:40 AM   #1
biken201's Avatar
Adco cover sticking to roof...
Yesterday, I removed the Adco cover that I had placed onto our new Roo for the first time about a month ago. As I was removing it, I found that it was sticking to the caulking/sealant putty at areas around the roofline. Has anybody else experienced this? And how about a remedy?
I hope everyone had a great Thanksgiving!!
11' Dodge Ram 3500 DRW 6.7 Cummins
12' Rockwood Roo 233S
Current: AZ
Wife: NY
Me: IL
3 Akitas (RIP D-Dog)
biken201 is offline   Reply With Quote
Old 11-25-2011, 09:44 AM   #2
Wax paper? Youroo!!
Old 11-25-2011, 12:32 PM   #3
rbq
This time of year most of us up north are trying to keep the HTT covered up from the snow & winter elements. Would be nice to be able to uncover & use.
rbq is offline   Reply With Quote
Old 11-25-2011, 03:31 PM   #4
I suggest Eterna Bond at your roof seams and any suspicious cracks in your caulking, around skylights or any other penetration points. Cover should slide right off unless you've got something sticky there. Eterna Bond won't adhere to silicone, use self leveling caulk on your roof.
2006 Rockwood 8272S
2005 Chevrolet Silverado
John & Pandra
Battlefield, Missouri
F.R.O.G. Member
1st International F.R.O.G. Rally Branson Missouri
JohnandPandra is offline   Reply With Quote
Old 11-26-2011, 05:17 PM   #5
rbq
As I watched my cover last night as the wind was blowing I noticed some billowing going on, so I don't know how it could stick to the caulking. I know that in the instructions we received with our Adco cover that it said not to over tighten the straps. If you have done this it may cause what you are describing. Suggest loosening up the straps a little.
Old 11-26-2011, 09:18 PM   #6
4Jeeperz's Avatar
Hey Biken201,
Our cover stuck to the roof "goop" a bit when new. Not a lot but a couple of places.
Has gotten better as trailer and caulking has aged. Maybe it's more of a warm/sunny climate issue.
4Jeeperz is offline   Reply With Quote
Old 11-27-2011, 09:48 AM   #7
Fire Instructor's Avatar
I've found over the years that if you cover too early in the season, or uncover too late, then the solar warm that is trapped under the cover (even though it "breathable") sometimes allows the cover to bond into the Eternabond or Dicor. Especially on corner and other places where the cover pulls a little tight.
We're about done for the season with too many 55F days here in upstate NY, so while I winterized a month ago, I'm covering today. Likely uncover in mid to late March. (hopefully!)
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 11-27-2011, 11:06 AM   #8
biken201's Avatar
Thanks for all of the input regarding the issue. My covering is mostly to protect from UV damage here in AZ, and not for winterizing protection. I try to keep it covered for most of the year whenever I am not imminently embarking on a trip.
I will try the waxpaper suggestion and see if it prevents the caulk from sticking to the cover. My next project will be to inspect the caulking where the cover was sticking to ensure that there is no "gaps" that will allow leaking...
Current: AZ
Wife: NY
Me: IL
Old 11-27-2011, 11:28 AM   #9
The sealant on a new unit remains sticky for quite a while if it stays clean. Our camper is over a year old, and the goop is still somewhat tacky, as the camper is stored indoors and stays clean. While a nuisance for the cover, I view it as a good thing as I think it reflects the quality of the sealant.
Maybe if you spread a very thin coat of silicone over the sealant, that might eliminate the sticking. I don't think it would hurt the sealant, although the silicone might not stick that well either...........
Maybe the wax paper idea is the best?
Old 11-27-2011, 02:34 PM   #10
My trailer stays outside and the roof sealant took about 4 months to cure. The first couple months it was extremely sticky. I'm not sure if it is air or sunshine that finally dries it out some, but the OP's trailer may just need more time without the cover.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
