Old 01-23-2017, 08:03 PM   #1
Add a separate circuit?
Hi all,
We just traded our 2015 Roo 19 for a 2017 Roo 23ikss. Making some modifications this winter and anxiously awaiting spring so we can go camping!
I just ordered a Progressive Industries EMT-HW30C and will be installing it when it comes in using TURBS idea of using 30 amp twistlock plugs, either in the bathroom sink cabinet or behind the power converter if there is room, I just haven't decided yet.
One thing I was considering though, and wondering if anyone else has done it, was adding a GFI breaker in the power converter and wiring the outside receptacle to it. I haven't pulled the converter out yet, but it appears that when I do, the outside receptacle should be right behind it, so it should be a pretty simple job.
We usually bring a Keurig and have it outside on a small table, and if someone in the camper starts an electric teapot or toaster we trip a breaker, so I think it would be worthwhile to have the outside on it's own circuit.
Any thoughts?
Dave
Misterpiano is offline   Reply With Quote
Old 01-23-2017, 08:14 PM   #2
Left Coast
I use a dedicated circuit for oil filled heater...
Old 01-23-2017, 08:39 PM   #3
Oaklevel's Avatar
I did this for a second circuit to the inside an outside should be similar. I added 3 outlets and a second AC to a 30A trailer. We use two 30A cords.
ID:	128548   Click image for larger version
ID:	128549   Click image for larger version
ID:	128550   Click image for larger version
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
