Old 05-24-2015, 09:18 AM   #1
RooVader's Avatar
Advice on bunk leak.
I realize it is hard to help diagnose but looking for suggestions.
I found a moist mattress corner when I first set up but hoped it was a poorly closed bunk. I now see that is not the case. If you look at the black tracks under the mattress, where two tracks meet in a corner is where I have water. It is a pretty stead wetness right there on that corner piece. I can't tell if it originates in the corner or runs down inside one of the tracks and ends up in the corner.
Is a likely culprit a bad seal of the canvas to the door? Any suggestions of an attack? Obviously I can drive to the dealer but hate to see how long I might be without this thing and I hate that thought.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
Old 05-24-2015, 02:21 PM   #2
RooVader's Avatar
I think I found several possible culprits so ignore/delete this.
2013 F150 FX4 EB
Old 05-25-2015, 08:40 AM   #3
yetavon's Avatar
Ignore what?
Retired Paramedic
2020 FSX 280RT
2005 Silverado 1500 Ext cab 5.3 H.O.
2011 HD Road King
Nights camped since 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
Old 05-25-2015, 12:00 PM   #4
RooVader's Avatar
Sorry that wasn't clear. I think I need to eliminate inadequate seasoning before anything else. Ignore my cry for help.
2013 F150 FX4 EB
Old 05-26-2015, 12:32 PM   #5
If anyone is interested in testing for leaks, I am an architect and the way we test buildings is with a hose, testing one section at time working from the bottom to the top of the section of concern.
Apply a stream of water for 10-15 minutes to the section being tested. Have a helper observe for the presence of water inside the RV. Wait 10-15 minute before moving on to the next section to make sure the water has time to perk through the system.
Using this method you can usually pinpoint the source of water penetration and address the leak.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
leak
