04-13-2014, 08:04 PM
Aluminum Wheel Lug Wrench
Just wondering what others have purchased to use as a lug wrench for the aluminum wheels; as a standard lug wrench, nor a thick socket fits in the lug bolt hole in the rim. I'm currently using a long standard socket on a breaker bar...that fits in there. What are you using?
Roocrew1 FL
2012 233S
2010 Expedition EL Limited 3:73 with Air Suspension
04-13-2014, 08:39 PM
Oklahoma Proud
I use chrome thin wall sockets and an impact, and to do a final hand torque, I have a 24"rachet with a 1/2"-3/8" adaptet and put the socket on it. I will break a few sockets a year, but i use them everyday. But that is why u buy a warrantee able socket like snapon or another brand.
Sometimes its whatever will work in a given situation!
MillerTime- Future Sabre Handler!!
04-13-2014, 08:43 PM
Thin wall socket, 6" extension and a Williams 0-250 lb/ft torque wrench.
04-14-2014, 06:48 AM
Just use my standard 4 way lug wrench and for the final tightening...a deep socket with my torque wrench.
04-14-2014, 07:01 AM
1/2" Drive Torque ----------------
1/2" Drive torque wrench can be purchased from Harbor Freight with a coupon for $11.99. It is not the best torque, but the specs are close enough to use on your camper aluminum rims and dedicate it to the camper. I store mine under the sofa in the pull out drawer.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
04-14-2014, 07:45 AM
Inexpensive torque thatvgoes up to 150#
3/8 to 1/2 adapter and deepwall socket.
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
04-14-2014, 08:14 AM
A standard 4-way will not work on some of the thin wall wheels where the lug nut is recessed back into the wheel. If you have a 4-way and think it will 'work', check it now before you hit the road and then find out that you have no way of getting your flat off. Do not trust that a tow service will have the right socket. My F-250 needs a Deep socket because of the length of the lug bolts. My last flat the AAA guy had to take it off by hand using my truck lug wrench as his impact was not deep enough.
Brother Les
04-14-2014, 10:58 AM
By the way.... I would also be interested to know what type of additional jack do you keep handy when hauling your camper? I "ALWAYS" carry an additional jack when hauling a trailer, but I haven't decided what is most appropriate for this Roo... as I only got it last Fall. I haven't tested my truck jack yet, I've just been hauling around my small shop jack.
Roocrew1 FL
2012 233S
04-14-2014, 11:13 AM
Over the years I have come to trust a jack less and less in changing a tire. I have measured and cut 2x6 treated boards and stack them in a pyramid shape and drive up or back up on it with the good tire. This will take the bad tire off the ground and maybe then I will use a jack to stabilize it some more.
Brother Les
04-14-2014, 11:27 AM
I don't pay much for these cause I keep all these in my truck tool box where they get beat around some. But, they are cheap and get the job done. I would not want to use them everyday like Turbs would in his job...but for occasional use, they work.
Harbor Freight flip impact socket set: (I really like this set)
4 Piece 1/2" Drive Impact Flip Socket Set
Harbor Freight 1/2 Torque wrench:
1/2" Torque Wrench
Harbor Freight 1/2" breaker bar:
1/2" Drive 25" Breaker Bar
Harbor Freight 12 ton bottle jack:
12 Ton Hydraulic Bottle Jack
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
04-14-2014, 01:24 PM
That's not only a great idea, but seems to be the safest. I'll definitely use that idea.
Roocrew1 FL
2012 233S
04-14-2014, 01:30 PM
Blocks are my preferred method as well...used them on a trip just last fall. I carry the bottle jack just in case the wood blocks can't be used for some reason.
"Old water skier"
