06-18-2015, 02:39 PM
#21
So what did you cut them with?
2016 Roo 23IKSS
2013 Ram Hemi 1500
06-18-2015, 02:42 PM
#22
Believe OC used a band saw
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
06-18-2015, 02:44 PM
#23
I cut one on my table saw and one on my vertical band saw. Couldn't figure out how to hold them in the horizontal band saw.
06-18-2015, 03:04 PM
#24
2016 Roo 23IKSS
2013 Ram Hemi 1500
06-20-2015, 06:26 PM
#25
That's all you need to cut is that little angle in the back?
06-20-2015, 06:29 PM
#26
It's all I needed to get them to fit on mine. I have since taken a belt sander and smoothed the corners to make them look better. LOL
06-20-2015, 06:30 PM
#27
I will be using them on a 2016 shamrock 233s. What do you have?
06-20-2015, 08:06 PM
#28
An old antique 2012 Flagstaff 8528RKWS 5er.
06-20-2015, 10:03 PM
#29
So you probably have a wider gap in between your tires
06-20-2015, 10:11 PM
#30
So you probably have a wider gap in between your tires.
About 2.5"
06-20-2015, 10:21 PM
#31
Dk-in-SC, what did you use to cut/trim yours down?
Sorry for the delayed reply. I was fishing for trout in the mountains. 😁
I used a small circular saw to cut them. The circular saw has the ability to pivot the deck for cutting at various angles. It worked well for the rough cut. To clean it up I used a grinding wheel. Not the best tool for the job but it worked. A belt sander would be better if you have one.
OldCoot's method was the one I followed. Notching the corner is the key to not having to trim too much off the small end.
I live with fear every day, and sometimes she lets me go fishing.
2019 Surveyor 251RKS
2008 Ford Expedition EL
01-01-2020, 06:59 PM
#32
Newbie- 21 FBRS
The old post showing the notch was good stuff! I used an oscillating tool and trimmed that corner down, as well as improving the front angle where I had shortened the length. Now my wife can get a leveler in the 2.5 inch space between the tires! This was a great find. Thanks.
01-04-2020, 08:31 AM
#33
Never leave home without them!
01-07-2020, 11:05 AM
#34
I agree with everyone they are awesome. I did find a issue last year when we were pretty un-level from side to side and had to put a board under to raise them up. I keep 2- 2x10x4' in the truck just in case. When i tried backing up on them they started to slide on the board and we had troubles for it gripping on but after some work they finally went. This year I am going to add some of the grip tape to the boards to help with this.
The wife and I have a great system where she just grabs the level and in no time it is level! So much better than stacking boards or blocks.
2021 Coachman Northern Spirit 2963BH
2017 Dodge Ram 1500 Laramie
Old:
2019 Rockwood ROO 233S, 1998 Dutchman 747SL, 1988 Jayco 1006, 2001 Skyline Nomad 3710BH,1997 Coachman Catalina lite 249 QB, 2001 Palomino Mustang SC
01-12-2020, 07:35 PM
#35
Another option that is cheaper too is the Camco Levelers. The reason I bought these is due to the size. They fit nicely between the tires and raise them up to 4 inches. Just something to consider.
_____________________
Current:
2019 Rockwood Roo 235s /// 2016 F150 Ecoboost 4x4
Previous:
2013 Jayco 19H /// 2012 Ford Flex factory tow package
01-13-2020, 12:12 PM
#36
Retired Panpsychist
Originally Posted by kennibc
Another option that is cheaper too is the Camco Levelers...{snip}
We used them last year and loved their smaller size for fitting in the space between the tires. However, we did find that the smaller size causes them to "bury" a bit in sandy soil. This year we'll cut a couple pieces of PT lumber and apply friction tape to keep the Camcos from burying.
Theo & Carol
2007 GoldenDoodle ("Cooper") R.I.P.
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
