Old 04-23-2016, 05:03 PM   #1
Anderson Levelers with 23WS
Does anyone use these levelers with the 23WS? If so, did you have to cut them down, and how much? It may be the same with all doubke axle Roo's, I don't know. Anyway, I'm spending a few nights on my way home from picking up my camper, and I want to be prepared. Thanks!
joinco70 is offline   Reply With Quote
Old 04-23-2016, 08:40 PM   #2
Here's some threads to try:
http://www.forestriverforums.com/for...kss-65728.html
http://www.forestriverforums.com/for...m-60137-2.html
http://www.forestriverforums.com/for...ler-73658.html
There a more. Search "anderson levelers mod"
2011 Traverse LT, 3.6L, FWD
Old 04-23-2016, 09:24 PM   #3
Originally Posted by rockfordroo View Post
Thanks, Rockfordroo, that was very helpful!
Old 05-17-2016, 12:02 PM   #4
172av8r's Avatar
On my '13 23SS, the tires were too close to use them as is. I cut 4" off of one of them (only need to do one) and that seems to work fine. Anderson's manual says you can take 4" off without impacting the leveler.
If I don't have to raise one side too far, I will sometimes just use one leveler. Using it on one tire gives you half the lift as with two tires.
2013 Rockwood Roo 23SS
2021Nissan Titan SV 4x4 w/integrated Tow package
172av8r is offline   Reply With Quote
Old 05-17-2016, 12:20 PM   #5
Originally Posted by 172av8r View Post
...If I don't have to raise one side too far, I will sometimes just use one leveler. Using it on one tire gives you half the lift as with two tires.
Not really the best thing to do suspension wise. Should use one under each tire.
Old 05-17-2016, 12:40 PM   #6
I use one Leveler and one Rapid Jack. When not leveling, I use the Rapid Jack as my trailer jack stand. Figure I saved the cost of one Leveler.
2015 Micro Lite 25KS
2006 Suburban 2500 8.1 L
220Chap is offline   Reply With Quote
