Old 03-08-2015, 09:54 AM   #1
Eric F.'s Avatar
Another 233S question. HWH!
Another thing the technician told me during my walk through was that if I run the ac and lp at the same time for the HWH, the ac heating element would get damaged.....
I know that if you run the ac with the tank empty you will fry it, but does the heat from the lp somehow affect the element as well?
And does the ac have a thermostat built in and shut off at a certain temp? Or does it just heat up to a pre-determined temp and stay on?
Thanks in advance for the help!!
Eric F.
2015 Flagstaff Shamrock 233S
2012 Ford F250
Eric F. is offline   Reply With Quote
Old 03-08-2015, 09:56 AM   #2
fonzie's Avatar
You can run both LP and electric at same time and no damage will occur. I have been doing for 4 years. Each system has it's own thermostat. Which water heater do you have: Suberban or Atwood and model number if you have?
Fonzie
Old 03-08-2015, 09:59 AM   #3
Eric F.'s Avatar
Thanks Fonzie. That's what I thought. None of that info is in the owners manual.
Eric F.
2012 Ford F250
Old 03-08-2015, 10:31 AM   #4
Engineer of Crazy Train
ChooChooMan74's Avatar
I run both on my Roo. I installed a switch so I can control the electric from inside.
Camping Life with Matt: Trailer Mod - Electric Hot Water Switch
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 03-08-2015, 10:40 AM   #5
geotex1's Avatar
Yep, run both as well - always have when there's shore power available.
geotex1 is offline   Reply With Quote
Old 03-08-2015, 12:22 PM   #6
bikendan's Avatar
Just make sure the WH is full of water, before turning on the AC side.
Otherwise you'll burn out the heating element.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-08-2015, 02:37 PM   #7
Since we, like most folks, arrive at our first campsite of the season in the late afternoon/evening, we light off the WH on LP. We then use the hot water for dinner prep and cleanup. After that, you can be sure the WH is full, then you turn on the AC.
2011 Traverse LT, 3.6L, FWD
Old 03-08-2015, 03:54 PM   #8
I am quite new to all of this and am totally in the fog with regard to all of the abbreviations for systems, components and tow packages. What is "ac" referred to in this conversation? And, is there a place where I can learn what all of these acronyms mean?
2014 Rockwood Roo 23IKSS
2012 Dodge Ram 1500 Hemi 4X4
Me, Hubby and Luna the Lab
sewingcybermom is offline   Reply With Quote
Old 03-08-2015, 03:58 PM   #9
geotex1's Avatar
AC = alternating current - i.e., 120V from shore power.
Have a read here about the HWH (hot water heater):
Suburban's electric switch and much more
Old 03-08-2015, 04:08 PM   #10
fonzie's Avatar
acronyms
http://www.forestriverforums.com/for...yms-50510.html
Fonzie
233, 233s
