04-09-2009, 10:23 PM
Newb
Another question - is there a trick
to getting the the glass thingy off that holds the water filter?
My DH was using the tool but it would not twist off. He was bending the metal that it was attached to, but it wouldn't budge. He had it off the other day when we were flushing the lines, but he put it back on w/o the filter. So today he went to do that and he couldn't get it off. It's filled with water and i suggested draining it, but he said that wouldn't make any difference.
Can anyone help?
CDR, U.S. Navy
Me, him, 2 kids, 1 dog
F-350 (V-10) to tow
2010 Rockwood Signature Ultralite 8317RKSS
04-10-2009, 01:17 AM
i bet he didnt get the o-ring back in and over tightened it . i did that and had to remove it from the camper and use the spanner wrench thingy and a pair of channel lock to remove the canister.I wasnt easy either
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
07-25-2009, 06:55 AM
Where is the filter housing? I bought my 23ss this Spring and have a filter but can't find where it goes. Typical beginner question.
07-25-2009, 12:50 PM
Mine wouldn't come off and I soon figured out to open a faucet with no water connected. When all faucets are closed it creates a vacumm, open one up and let all the water drain out and it should come right off, at least it did in my case.
07-25-2009, 03:29 PM
Moderators' Assistant
it should be in the cabinet between the sofa and the front bunk. that's where the water pump is.
of course, i have a 2007 23SS.
not sure if that's where yours is. there have been some changes since i bought mine.
the newer ones have the water tank underneath, whereas mine is in the cabinet by the door.
but i think the water pump is still in the same place.
09-01-2009, 08:37 PM
Can anyone help?
I use a oil filter wrench to unscrew glass housing that holds the filter... Filter wrench is the "strap" kind that needs a ratchet to tighten/turn the filter... good luck,, Greg
09-02-2009, 11:44 AM
Yep, you should release the pressure. I had the same problem on the one in my trailer and the one in my house. Once the pressure was relieved, they came right off.
2007 Surveyor SV291
Equil-I-zer hitch
2005 Durango Hemi
02-16-2011, 07:03 PM
I have determined that the canister filter is a PITA. I put no filter in there an use an in line filter on the outside. So much easier
02-17-2011, 11:19 AM
The Old Man
My long term plan is remove the filter housing completely that is inside the trailer. It is in a ridiculously inconvenient location! I have to lie down and wedge myself between the toilet and vanity and reach deep into a cabinet. Whoever designed it this way sure didn't have the consumer in mind. It's almost impossible to avoid spilling when changing and makes winterizing just that much more difficult.
I just added my own filter to the outside. The whole thing including the bracket is easily removable for traveling.
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
02-17-2011, 01:12 PM
Moderator
Just out of curiosty Willis, where did you get that filter and how did you get up enough never to screw something into the outside of the trailer skin. Is it located in any special place or just screwed to the body where convient? I was wondering what is there for the screws to catch beside the skin?
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 528 |
| 96 members and 432 guests |
| 4bnabird, 4runner freak, 87CrewDually, andrew963, Bandit7, bclemens, bikergirl, BlakeB, bob213, bob34787, Ca Cardinal, Canuck_Doug, Cascade Bob, cat1956, cbconway, cdbus, concours14, cstover, DAISY BOYKIN, danred, daveg, davegood, dfrauhiger, Diedrich, dimurrrw, dknight903, dlmurray51, DonG, donn, fonzie, fordmantpw, FreedomTracker, GAS MAN, grhodes50, Happy Vibe, herk7769, hjmiberry, Hob, Iggy, jacksum2, jamiller45, jdefeo1, jerrygallion, Jestercyco, jjacon, jkinger, Jo54, johnthecamper, Jonesy, Joseph5410, jsutherl, J_King, kegoneill, Kmckruit, leayellow, lemoj1, LeNe4847, lmcleister, Lonewolfcry, Loui, mcbride5, merlin66043, mhartzel, micalo, MilCop4523, NeilM108, ng2951, nuisance, Painless, pappcam, ParrotHead, pchrcane65, photog, ret2006, RJHuser, rschoono289, sabre5er, Sailfish Bret, SCOC, Scriggs1, SDENN4281, sideout1961, simon, Slow_movin, Tee, texwolves, Triguy, trudinator, T_LMurphy, VTX Al, wayne anthony, william.migues, wolfpack21643, wvbike_99, wvcampers, Zama |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
