Old 09-20-2016, 06:03 PM   #1
Antifreeze inlet
Name:	ImageUploadedByForest River Forums1474412135.136892.jpg
Ok so I'm a new owner of a shamrock 233s and winter is right around the corner...so I like to be prepared....I'm trying to figure out this system for winterization.
On the front right side of the tt there is a antifreeze inlet right next to the city water inlet...do I just have to connect a hose to it and run the water pump to suck up the antifreeze from the gallon jugs?...could it be that easy?
metalmike57 is offline   Reply With Quote
Old 09-20-2016, 06:10 PM   #2
One more thing....on the opposite side(left of the door) there is a tank flush inlet?...how Does that work?...both gray and black water or is it for the clean water holding tank?Click image for larger version
Name:	ImageUploadedByForest River Forums1474412984.525995.jpg
ID:	120837Click image for larger version
Name:	ImageUploadedByForest River Forums1474413007.414942.jpg
Old 09-20-2016, 06:15 PM   #3
Ford Idaho's Avatar
BE SURE you have bypassed the water heater BEFORE you start.
The lite came with the hose/tube for this, it was in a drawer.
The way I do it.
Just turn the water pump on and then open one faucet at a time, I like to start near the water pump and work away from it.
Takes me about 30 minuets including pouring some in the toilet bowl and an extra jigger in each drain.
Be sure to do the outside shower if you have one as well as the low point drains.
Old 09-20-2016, 06:19 PM   #4
I'm just here to read the reply's.......................
2016 Rockwood ROO 233S
2013 Ford F150 3.5 ECO SCREW
TT233S is offline   Reply With Quote
Old 09-20-2016, 06:25 PM   #5
The tank flush is to flush out your black tank after emptying it. There are nozzles that spray around in the black tank. Do not use your drinking water hose for this for sanitary reasons. And DO NOT walk away with it spraying in the tank with the black valve closed. You will find numerous stories on the forums about water (and whatever else) coming out the vent on the roof if you forget to shut it off.
I don't know what a fullway termination valve is. Maybe the black tank valve?
David, Sherry and our three fur kids, Nicholas, Finnegan and Bentley
2013 Coachmen Encounter 36BH
2014 Honda CR-V/ Blue Ox Patriot II
DSurette is offline   Reply With Quote
Old 09-20-2016, 06:25 PM   #6
bubbles's Avatar
Seems to me that a valve has to be selected to switch the pump over to that port. I don't think it can be active all the time and still get water from the holding tank. The cleanout is for the black tank. Just follow the "CAUTION" label.
Old 09-20-2016, 06:28 PM   #7
Don't forget the checkvalve in the city water fitting
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 09-20-2016, 06:28 PM   #8
Ford Idaho's Avatar
Originally Posted by metalmike57 View Post
One more thing....on the opposite side(left of the door) there is a tank flush inlet?...how Does that work?...both gray and black water or is it for the clean water holding tank?Attachment 120837Attachment 120838
Likely for the black tank only.
Drain Black tank first close the valve.
Drain Gray tank then close the valve.
After hooking a one purpose hose to the trailer and spigot turn on the water.
IT is VERY important that you do NOT walk away or become distracted at this point.
Let the water run for about 10-20 gallons of water(depends on tank size) then open valve.
Repeat till water runs out clear.
Old 09-20-2016, 07:07 PM   #9
I had a pop up before this and I am familiar with the winterization process....just a little confused about the antifreeze inlet...is it that the water pump works with this and not the city water inlet?...would there be any water in the city water inlet that could freeze?...do I connect the hose to the city water and fill with antifreeze?does the water pump work with that?...probably not...
Old 09-20-2016, 07:09 PM   #10
And the black water flush inlet on the other side do I pump in antifreeze into that , when I'm done?
....if so how?...hand pump?...I have one for my pop up
Old 09-20-2016, 07:14 PM   #11
With antifreeze in the system and pressurized pull out the screen on the city water inlet and there is a checkvalve to keep pump pressure from pushing out water. Press in hard in the little nipple, and stand out of the way. This will push the antifreeze out of the city water connection.
Old 09-20-2016, 07:22 PM   #12
I thought that check valve was on the fresh water cap or connection?...it's dark here now (ny) I'll check it out tomorrow...thanks
Old 09-20-2016, 07:25 PM   #13
Oh...with the antifreeze being pumped in push in that check valve on the city water inlet and antifreeze will shoot out...is that what you are saying?
Old 09-20-2016, 07:25 PM   #14
Not the tank fill but the city water connection
Old 09-20-2016, 07:52 PM   #15
bubbles's Avatar
I could finally make out what the antifreeze sticker says about the valves for winterizing. Just need to find those valves. Both of the ports in question have instructions for what to do. Just follow them.
Old 09-20-2016, 08:52 PM   #16
Ok thanks everyone....getting late here gonna check it out this weekend ....still got a couple of trips planned before I winterize it...
Old 09-26-2016, 02:03 PM   #17
Old Eeyore's Avatar
No. All you have to do is flush the toilet to get a little AF into the tank (after you've flushed and drained it as much as you can).
2022 Rockwood 2608BS / 2019 Silverado 1500
2016 Rockwood Roo 23IKSS / 2019 Silverado 1500
2011 Rockwood Roo 21SS / 2011 Tahoe
2006 Fleetwood Bayside / 2006 4Runner
1999 Coleman SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
Old Eeyore is offline   Reply With Quote
Old 09-26-2016, 02:46 PM   #18
Yes you do pump antifreeze in the black water flush. A lot of water I'd left in that line depending on how the back flow preventer is installed. Or you could blow air in it also.
antifreeze
