Old 06-16-2016, 12:53 PM   #11
djemgoss's Avatar
This is what I do with my Roo 21SS. I lower the bunk from the outside and then go back inside. I remove the pole from between the mattress fold and reach over the top of the mattress and raise the frame up and insert the pole into the frame socket and then attach the other end of the pole to the first or second notch in the bracket. Then lower and position the mattress. I'm tall so I can reach over the mattress without a problem.
Practice helps! Good luck!
Dave & Elaine
Brookfield, WI
2016 Rockwood, ROO 21SS, pulled by a 2015 F150 XT, Super Cab, 2.7L Eco Boost, with 3.55 axle. Electric 6-speed auto trans w/tow mod. Tow package & integrated trailer brake. 7,600 lb. tow capacity. 145 wheel base. Equalizer 4 point W/D hitch.
djemgoss is offline   Reply With Quote
Old 06-16-2016, 01:12 PM   #12
wicked1's Avatar
Originally Posted by taz_co View Post
From what I understand, this is the correct way to store the frame and mattress, short or long term.
FYI, when closing up, after the pole and frame are disassembled, turn both exhaust fans on high. When you close the trailer door, the suction created by the exhaust fans will suck the tent ends in, enabling you to close up the bunk doors with much less chance of catching extra material in the seals.
Yep fans on high all windows closed and main door creates suction on tent end material you can close up with one hand, works for me every time
2016 F350 CREW 6.7 PowerStroke Diesel
2015 FR Rockwood Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 06-16-2016, 01:39 PM   #13
cogito ergo moo
Cowracer's Avatar
Originally Posted by Hemlock04 View Post
Thanks for response and I do use setting with the least strain. Maybe I described it wrong. When you open the bunk end the mattress is folded up and sitting on the shelf and the white tent frame is on the door. What do you do at that point? It appears that taking the mattress right off the shelf would be easier than reaching in and lifting the tent frame high enough to get the pole on it. That is when I am pressing down on the mattress, I am not even close to attaching the pole to the bracket yet. The pop up tent end was much easier than this. There has to be a better way than what I am doing.
Oh ok.. I see what you mean.
I lay the tent 'hoop' and pole on the mattress and then fold the end of the mattress over them (like a taco), then I fold the bunk end up,
That way, you drop the bunk, flip over the end of the mattress and there is your pole and hoop ready to go. Easy peesy.
And yes... The fan trick when closing up works great, but also open a door or vent when opening up. Makes it so much easier.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 06-16-2016, 02:27 PM   #14
bikendan's Avatar
so, our old bungees/snaps tent ends do have some advantages to the new permanently attached ends.
the DW doesn't have to get inside the tent end to do anything.
i stand outside and can pull up the tent support hoop while she pushes it with the shepherd's hook.
and we can put bedding on the mattresses together, without either of us having to go inside the tent and on the bunk door on hands and knees.
she stands at the ledge and i'm standing outside.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-17-2016, 05:09 AM   #15
Mainframe's Avatar
The same thing happened to me when I got my 23ws LOL I brought it home and the hoop was under the mattress! (The tech put it under there after the PDI, he insisted on folding it himself) I had a heck of a time getting it out of there in the back bedroom, I actually almost stuck it back under the first time I folded it and quickly tried folding it all up with the hoop on top of the mattress (proper way)!
I just pull the mattress back, pop the pole off and the hoop just falls down over the mattress, go outside and lift the end up and latch it, takes only seconds. Super easy!
But I can see how you might be VERY frustrated if you are thinking the hoop needs to be under the mattress each time.
2016 Shamrock 23WS
Mainframe is offline   Reply With Quote
Old 06-17-2016, 05:28 AM   #16
bikendan's Avatar
We have an older Roo without the pre-attached canvas.
So it's easier to setup the tent ends.
We do fold the hoop support in the mattress.
