Anyone having issues with curtain rod holders pulling out?
Hi guys,
Is anyone having problems with the curtain rod holders pulling out of the wall? If not, then maybe my problem is unique. Otherwise, does anyone have an idea of how to fix it? The screws pull out and the flat curtain rod can't be reconnected because the holes are stripped.
The holes stripping is a fairly common problem. You can either get some very small mollys or what I usually do is get some Elmers glue and glue toothpicks in the hole(dip one end in the Elmers and squeeze as many toothpicks in the hole as you can). Let it dry overnight and cut off the part of the toothpick that is sticking out so that they are flust with the wall. You can then put the screws back in and it should hold.
Good luck!!
Tom and Margaret
2014 Berkshire 390bh-60
