Old 09-09-2013, 10:09 AM   #1
urocav2001's Avatar
Anyone move there hot water tank switch?
I'm looking into moving my hot water tank switch into the panel by the door with the same style switch as the water pump that lights up, is this fairly easy?
urocav2001 is offline   Reply With Quote
Old 09-09-2013, 03:18 PM   #2
Check out this thread: http://www.forestriverforums.com/for...ight-9008.html
...VTX-Al
VTX Al is offline   Reply With Quote
Old 09-10-2013, 08:28 AM   #3
i have been wondering the same thing. seems like a poor design to have to go outside and open the outer cover to switch on to use by electric but have a switch on the inside panel to use for gas. Mom had 2009 Jayco and both switches were inside on the main panel. Why wouldnt FR make them all with both switches on the. seems like the cost would be very little. A few feet of wire and a switch
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
https://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 09-10-2013, 08:33 AM   #4
TURBS's Avatar
Depends on the fr line as my fr sabre has a factory inside wh switch.
Old 09-10-2013, 08:48 AM   #5
To me this is something that should be standard on all models.
2013 Ram 1500 (5.7)
Old 09-10-2013, 09:09 AM   #6
urocav2001's Avatar
It should be from factory like that!! So I should just reroute the wires from the switch to the factory panel and pop a switch in there I'm thinking. Anyone have a wiring diagram of the hot water tank!
Old 09-10-2013, 09:09 AM   #7
Send a message via Yahoo to Jim Spence
That switch on the heater sure tought me a lesson about drying hands, before I reach in there!!
05 34CKTS Cedar Creek
swivel wheel trlr
2000 Dodge 5.9 LB QC dually/4x4 manual lockers/BD EXH/ EZ Chip
07 Polaris Sportsman
09 Yamaha V Star 250
Jim Spence is offline   Reply With Quote
Old 09-10-2013, 09:57 AM   #8
Triguy's Avatar
These should be of some help for you...
Forest River Forums - Downloads - Water Heater - Suburban Operation
Forest River Forums - Downloads - Water Heater - Suburban 6 Gallon User Guide
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-10-2013, 10:02 AM   #9
urocav2001's Avatar
So if I'm reading the diagram right there's only a black wire on the switch so what would I use to put in a lighted switch? Just ground the switch?
Old 09-10-2013, 10:05 AM   #10
Triguy's Avatar
I was afraid you'd ask that
I'm just supplying the info as I've not done the mod you are looking to do and I would also need to study up on it.
But, I'll be very interested to read a report/tutorial on how this goes for you (especially since I think we have the same trailer -- Shamrock 233s) .
Scott
2012 Shamrock 233S
Old 09-10-2013, 10:09 AM   #11
urocav2001's Avatar
Yeah lol I'll include how many times I get zapped too!! I hate electricity !!! Lol
Old 09-10-2013, 10:14 AM   #12
Triguy's Avatar
I just did a Tough Mudder challenge this weekend. Lots of electroshock therapy. Trust me - I can relate!
Scott
2012 Shamrock 233S
Old 09-10-2013, 10:35 AM   #13
wmtire's Avatar
Just making sure you understand that most (if not all) of the switches on your control panel are for 12 volt stuff.
Your water heaters electrical heating element is 120 volt, and thus needs wires/switches for that. Make sure you plan/buy accordingly.
2011 Flagstaff 831 RLBSS
Old 09-10-2013, 10:35 AM   #14
Broken Toe
Cowracer's Avatar
If you pay attention, and follow the rules that cost the lives of guys before you, there is NO reason to get zapped.
I've been working with electricity for over 20 years and I'm not talking about your run-of-the-mill 120VAC wall current. I'm talking lots of 460, 2300 and 4160VAC three phase. Over all those years I can distinctly remember every time I got zapped. Both of 'em. Yep, in over 20 years I've been bit exactly twice. Both were over 10 years ago, and both times I got in a hurry and didn't pay attention.
If you take a few minutes to learn the basics, and use the proper tools and procedures, a 12 year old child could safely change an outlet or rewire a lamp.
BTW if you do this mod, MAKE SURE YOUR SWITCH IS RATED FOR 20AMP 110VAC. Many smaller light up switches are only good for 10 amps, and would not be able to supply the water heater safely.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 09-10-2013, 10:52 AM   #15
urocav2001's Avatar
Ok thank you
Old 09-10-2013, 11:33 AM   #16
Denver, CO
garbonz's Avatar
I decided to interupt the power at the breaker and run a switch right next to the power distribution panel. I don"t have pics right now but will take one tonight.
2017 Fuse 23T
Old 09-10-2013, 02:23 PM   #17
I guess you didn't even bother to check the link that I supplied for you. It explains how to install a lighted switch and why you need three wires.
...VTX-Al
Old 09-10-2013, 02:30 PM   #18
urocav2001's Avatar
No I looked at it, I have a 233s and my hot water tank is in a different location, I'm trying to take out the existing switch on the tank behind the access door and just put a switch in the panel, My tank is in the front of the coach under the seat
Old 09-10-2013, 03:19 PM   #19
wmtire's Avatar
What I see most people doing (as it is easier) is to put in an inside switch either
A: in the circuit between the breaker and the 120 volt outlet the water heater plugs into (which then controls the power going to the outlet)
or
B: at the water heater 120 volt outlet itself, to turn off/on the outlet.
In either of these scenarios, they are just placing basically another switch upstream of the on/off black switch on the front of the Suburban water heater. They leave in the black switch, and keep it in the on position.......then use the upstream inside switch to control the 120 volt circuit the water heater get's it power from.
It would be easier to not take out the black switch, but just install another switch in it's circuit, somewhere.
Old 09-10-2013, 03:24 PM   #20
Too bad they don't make 20A. Clappers....
Hudlow is offline   Reply With Quote
expandable, hybrid, shamrock
