Old 06-13-2013, 09:13 PM   #1
Hostile2camp's Avatar
Awning not flush with camper
Curious if others with power awnings look like the pictures I have attached? It doesn't retrack back flush with camper and not sure if that is normal or if there's a problem. New 14 ikss..
ID:	33080   Click image for larger version
ID:	33081   Click image for larger version
Hostile2camp is offline   Reply With Quote
Old 06-13-2013, 09:31 PM   #2
Dennis and Julie's Avatar
I think that's how they are. Our 2012 Flagstaff is the same way.
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
Dennis and Julie is offline   Reply With Quote
Old 06-13-2013, 09:35 PM   #3
Looks good to me. The awning roller will not be flush with the wall. The arms will be seated against the wall supports. You will notice the movable arms are designed with an offset on both sides that fit over the wall supports. To assure it goes out and back in correctly all the time, I suggest you deploy the awning, measure from the white cap on each end to the edge of the material and center the material on the roller and mark the edge of the material on the roller. Retract the awning and then deploy it again and check to see if the material moved on the roller. If it didn't move, drill a 3/16" hole thru the hem of the material on both ends like the attached picture and using a large flange pop rivet, rivet both hems. The material without being riveted tends to move on the roller causing it to bind when trying to close. The rivets prevent this and will not harm the material.
The picture shows this awning deployed too far and is for the purpose of showing where to rivet. The awning should only be deployed far enough that the material is on the top of the roller and there is no valley made with the roller. I hope this is what you were wanting.
Old 06-13-2013, 10:14 PM   #4
Great stuff thank you guys. To be clear you suggest the rivets so it doesn't slide from one side or the other on the roller correct?
Old 06-13-2013, 10:17 PM   #5
That is correct. The awning material is already centered at the trailer and screws are installed at 2 places to insure it doesn't move on the trailer.
