09-28-2015, 02:37 PM
#21
I will say the ones OC sells are nice but when you can make something on your own that works, there is no feeling like it 😄
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
09-28-2015, 07:08 PM
#22
Originally Posted by TURBS
Pretty un level ground you got there! [emoji85]
take your pics with phone sideways not up and down and your pics will be normal.
If you do take pic with phone in portrait " up and down" you have to slightly crop photo for it to be in the correct position.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
I'll have to do that next time, yes it was uneven and the tree branches were actually under the awning. The camp maintenance guy came by and pruned them back a bit. When I added the screen room I had to put the door at the back as the tree was in the way as well.
09-28-2015, 07:13 PM
#23
I totally agree
It's a great feeling
Plus I've had others at different campsites comment and take pictures
That makes you feel even better
#24
Nice job your solution will work as well as anything offered here at a much lower cost. I like your ingenuity!
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
09-28-2015, 07:33 PM
#25
[emoji10]
TURBS
2011 32bhok Sabre
09-28-2015, 07:48 PM
#26
2015 Roo 23IKSS
I got these from Harbor freight 2-in-1 Support/Cargo Bar Modified the top mounted originally similarly to OP's method, got got new parts to mount it differently. These are adjustable so they worked good when the ground is uneven.
Think about things before you do them make life easier not harder.
09-28-2015, 07:56 PM
#27
2 for $28.00 and they collapse to 45 inches...
09-28-2015, 08:22 PM
#28
OP they look great and there is nothing like a job well done by yourself. When given the choice, it's self satisfaction and cheap with labor or easy, less labor and more expensive. I was lazy and even got Herk and DH to install mine with Turbs supervising.
2014 Sabre 34REQS-6
09-28-2015, 08:29 PM
#29
Originally Posted by asquared
...with Turbs supervising.
That's what he does best, supervising Ms. Amy while she cuts and splits wood, cleans, waxes the camper, truck, cars, mows the lawn and works 10hrs a day as a nurse.
09-28-2015, 08:36 PM
#30
Wow does that sound familiar..... I wash and wax the rv and my truck (unless I pay the neighbor in beer to use his mobile detailing business stuff on it). I clean the trailer, load the trailer, drive the trailer and pay the lawn guy cause Dh won't mow our hills. And I also work as a nurse. I also make dinner, take care of getting dd bathed and off to bed etc. While a certain dh gets to watch tv and tell me she's up too late. Gotta love independent women!
2014 Sabre 34REQS-6
09-28-2015, 10:32 PM
#31
Who to contact for info?
09-28-2015, 10:50 PM
#32
I'm gonna have to get DW on here so she can learn a few things
2003 Duramax
2010 Blue Ridge
1 DW
1 mutt
on occasion 1 DD
09-28-2015, 11:45 PM
#33
OC's Awning brackets
Turbs Awning poles
These two items put together work well. Many bug the brackets and then use painter poles for the hold down poles. I like these because they come predrilled and with everything you need except a rivet gun and rivets.
2014 Sabre 34REQS-6
09-29-2015, 06:02 AM
#34
Sounds like a true Jersey Girl
09-29-2015, 07:00 AM
#35
When I made mine, I used 6063 Aluminum on the poles which was a little bit more expensive. The brackets were milled from a block of ABS. All the holes in the tubes were put in on a Bridgeport. The whole system was a government job made during some slack time. It turned out very well. No plans of making a production out of it though
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
09-29-2015, 09:24 AM
#36
I've got a question regarding these tie downs. How much wind is the awning material itself going to withstand before the awning needs to be retracted? Even though the awning frame is well secured, the material is going to catch the wind and, being flexible, will be flopping around somewhat. It seems that at some point, maybe just short of a gale, it is going to either rip, tear, or pull out of the channel at the trailer. So, at what point do ya'll go from 'oh, don't worry; it's no problem' to 'Oh crap!'?
09-29-2015, 09:47 AM
#37
I really do not know, common sense should tell you that. If the wind was over 30 plus and depending on the angle of it hitting the awning I guess a person would know. I know I have been in that much wind and really didn't have problem with material If it got much higher I don't think I would test it. I like to be next to the BIG BOY'S MH that I can use as a wind block. I have seen all kinds of awning supports on this forum and they are all 100% improvement. But I will give credit were credit is due, Thanks for the idea OC on pole support instead of just tying them down. Tying them down just bent your roller and caused a lot of banging been there and done that.
Coachmen M/H
Concord
2018 / 300 DSC
09-29-2015, 10:52 AM
#38
Radioman
Awning supports today's project
I like it simple. Two 5 gallon buckets from Home Depot filled w/water strapped to the awning and just barely touching the ground.
Radioman
2005 Ram 3500 4X4 Diesel
2013 Silverback
Yuba City, CA. 95993
09-29-2015, 11:20 AM
#39
[QUOTE=asquared;996496...you need except a rivet gun and rivets.[/QUOTE]
Bracket kits come with rivets.
09-29-2015, 11:24 AM
#40
Ya gotta store the buckets, those of us with poles don't have to remove them or store them, they store on the awning arms.
