Old 02-21-2018, 05:54 PM   #1
Axle Replacement Cost
I need to get a new axel on our 2013 Shamrock which I see eTrailer has for about $300+ with wheel hubs. Local big name dealer just quoted $1500 installed just for axel which seems insane. Anyone have an axel installed and what did you pay? Thanks.
arctic318 is offline   Reply With Quote
Old 02-22-2018, 01:36 PM   #2
Swing by a local utility trailer place and see what they'll charge you to replace the axle. I bet it's a lot more reasonable than an RV dealer. And they'll probably do a better job.
Gotta go campin!
Old 02-22-2018, 01:42 PM   #3
What that basically means is that they don't want to do it, but if you're stupid enough to pay $1500 they will.
Old 02-22-2018, 02:02 PM   #4
Brother Les's Avatar
Changed out my own axle.... that did not come with hub/brake assembly. I changed over the hubs/brakes to the new axle.
Not hard to do if you have a friend or two. Flat area to work, Heavy Jack stands, floor jack. Basic tools to remove/replace axle to leaf springs.
If you do not want to change your own axle. Look for an independent RV shop or trailer shop. A shop that knows what they are doing will take about 2-3 hours. No messings with changing over hubs and brakes. Lift up unit... snip wires, drop old axle, roll out of way. Roll in new axle, attach to leaf springs (this would be a good time to replace the leafspring Bushings before attaching new axle) Re-attach wires... test wiring/ brakes... drop unit on the ground and good to go... MY estimate... no more than 400.00
Brother Les
Old 02-22-2018, 04:21 PM   #5
gectisme's Avatar
Not sure what type of axle you have but we had two, 4K lb Torsion Axles replaced last year and the labor was ~$450 from an independent shop in Iowa. The axles came from FR under warranty so I don’t know what they cost. Hope that helps. [emoji106]
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 03-06-2018, 08:12 PM   #6
I wanted to provide an update that I found a trailer build/repair shop (all trailers, not just camping) and out the door $560. Another RV dealer was $1000 and the original RV Dealer was $1500. Took a while to find this shop, but to save $500-$1000 was worth it.
replacement
