Old 10-07-2014, 04:05 AM   #11
dado39's Avatar
How did they work ?
2014 roo 233S. 2008 saab 97x
dado39 is offline   Reply With Quote
Old 10-07-2014, 10:39 AM   #12
husky family's Avatar
I'm very happy with these stabilizer bars. I mentioned that I had to add a cross member at the rear of the camper to support the mounting - but the angle I used is not quite sturdy enough - I see some flexing in the angle. I'm going to find some box tube or more robust steel to remake this support. Otherwise...this made a ton of difference!
Here are some pictures of the front stabilizers. Here I used the self-taping screws provided and mounted the pivot directly to the frame.
I'll add more in the following posts
ID:	64256   Click image for larger version
ID:	64257   Click image for larger version
2014 Rockwood Roo 233s
2014 Runaway Navigator
2013 GMC Yukon XL
husky family is offline   Reply With Quote
Old 10-07-2014, 10:44 AM   #13
These pictures of how I mounted the stabilizers to my scissor jacks. They did not mount "out of the box" because of the direction I wanted to mount the bars. At the end of the bar you have an L-bracket on a loose rivet for pivot. Great design, but it only works if you mount the bars going front-to-back. I wanted to mount them side-to-side (hope that makes sense). I also included 2 pictures from the instructions and from the packaging (showing the front-to-back mounting).
So what I did was use a longer shoulder bolt in the scissor foot pad. I used washers on each side of the stabilizer bar mounting and tightened the nut - but left is loose enough that it could still pivot. Then I used a lock nut to keep it all together. I then oiled the pivot point. Not sure if this is the best solution, but it's a solution. I will monitor this to be sure it doesn't wear funny.
ID:	64260   Click image for larger version
ID:	64261   Click image for larger version
ID:	64262   Click image for larger version
2013 GMC Yukon XL
Old 10-07-2014, 10:51 AM   #14
The rear bars were more tricky to install because of no cross member. I bought a 6' piece of angle from Lowe's for $22, cut it to length and painted it black. I mounted it to the scissor jack mounting bolts. The holes in the angle were nearly perfect, but I opened them up slightly so I didn't damage the threads while negotiating it on the bolt. Then I used 5/16 bolts to secure the pivot end to the angle. Same mounting as above to attach to the scissor feet.
Like I mentioned above, this new member is not strong enough and I see deflection when I push on the sides of the camper. I'm going to find something more rigid and replace this perforated angle. But even with this installed...much better than not having the stabilizers at all.
ID:	64264   Click image for larger version
ID:	64265   Click image for larger version
ID:	64266   Click image for larger version
2013 GMC Yukon XL
Old 10-08-2014, 12:53 AM   #15
dado39's Avatar
Thanks for the pics and then info looks like a spring project
Old 10-08-2014, 06:23 AM   #16
I belive the prefered way to install these is to aternate directions. The way you have all four the same will proved side to side support but not front to back support. On my 21ss, I could only install one of four in the front to back config but it did help. If you cannot get one front to back than make sure u at least use a between the wheel chock. Happy camping
Silverado HD 2500 6.0 Crew Cab
2014 Roo 21ss
sdelam is offline   Reply With Quote
Old 10-08-2014, 06:34 AM   #17
camper1999's Avatar
I looked at other stabilizers for the front landing gear of my fifth wheel and mostly were pretty expensive. I installed the Bal stabilizers I bought for around $55 and they work great.
2011 GMC 2500HD Diesel
Old 10-08-2014, 09:38 AM   #18
sdelam,
You're correct. I only wanted to correct the side-to-side movement. I do use between the wheel chocks that take care of my front-to-back movement. I have seen some FRF threads where people have installed 2 stabilizer bars on each scissor jack. That would give you the most rigid solution.
2013 GMC Yukon XL
Old 10-08-2014, 01:21 PM   #19
bikendan's Avatar
Just a comment.
We've had our 23SS for nearly 8 years now and we've never felt the need to add additional stability devices like these.
I can see how the 3 bed hybrids might need though.
But for the two of us, the stock stabs and the tandem chocks keep our 23SS solid.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-09-2014, 09:16 AM   #20
Originally Posted by MuddauberE View Post
I have a 2013 Roo 233s. I experienced the same thing you were talking about. To keep this short, I have installed the BAL stabilizers and they work wonders. A HUGE difference in not having them. The trailer hardly budges now when the kids are in the back bunk.
MuddauberE, how did you mount the rear BALs? Did you add a cross member or did you mount them front-to-back?
2013 GMC Yukon XL
hybrid, roo, stabilizers
