Old 01-13-2016, 07:53 PM   #1
Barker Tote use with Roo/Shamrock 19
I'm looking at purchasing a 32 gallon Barker Tote for my Roo 19. Anyone have any issues with the waste water drain on their Roo/Shamrock 19 not being high enough to allow the waste water to flow down into the 32 gallon Barker Tote? Thanks in advance for the info.
2016 Roo19 Hybrid
2015 GMC Sierra 4x4 Crew Cab
OK3wire is offline   Reply With Quote
Old 01-13-2016, 08:57 PM   #2
Left Coast
Get the end cover for tank valve that has a garden hose attachment
Old 01-13-2016, 09:17 PM   #3
I have a 233 with Barker 42, same issue. Barker top fill is a little higher than waste drain. I use the included slinky hose and basically create a p-trap and let it fill. to disconnect, i lift up on hose to empty into barker, then disconnect camper side, then barker side. Only a few drops spilled. I only use for grey water, so not that big of an issue.
mitchlandry is offline   Reply With Quote
Old 01-13-2016, 09:19 PM   #4
@Bob,
I'm not quite following you here. Can you please explain what you mean? Thanks.
2016 Roo19 Hybrid
Old 01-13-2016, 10:37 PM   #5
RedStick's Avatar
OK3wire, you could purchase something like the Camco 39463 Sewer Cap with Hose Connection and use a small garden hose (not fresh water hose) to drain the grey water from your Roo to your Barker.
It may take a bit longer, but it is much easier when dealing with elevation issues.
2013 Rockwood Roo 23ss
2012 F150 Ecoboost
Camped for 12 nights in 2015 - too many cancellations
Camped for 25 nights in 2014!
Camped for 24 nights in 2013!
RedStick is offline   Reply With Quote
Old 01-14-2016, 12:11 AM   #6
My next investment will be this.
FloJet RV Waste Pump Kit - Xylem 18555000A - Drain & Flush Systems - Camping World
Can just leave tote in back of a truck if you want.
roo, shamrock
