Old 06-26-2016, 10:21 AM   #1
urocav2001's Avatar
Battery charging
Does anyone know how long it would take to refresh the batteries when plugged into a generator?
urocav2001 is offline   Reply With Quote
Old 06-26-2016, 10:47 AM   #2
raspivey's Avatar
Too many variables. Battery size, charger output, and depth of discharge being the main ones.
2012 Chevy Tahoe LTZ - HD tow package
Old 06-26-2016, 11:47 AM   #3
Moderators' Assistant
bikendan's Avatar
Yep, no way to answer the OP'S question specifically.
But we have two 12v deep cycle batteries.
We can go 3-4 days without recharging the batteries if we keep furnace usage to a minimum.
It takes about 3 hours to recharge them.
NEVER let the batteries go below 50% charge.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 06-26-2016, 04:23 PM   #4
urocav2001's Avatar
Ok I will be dry camping for 3 days, using fridge on propane and a few LED lights before bed, that's about it, we just have 1 battery that came with the unit, and the generator is fairly small
Old 06-26-2016, 06:49 PM   #5
raspivey's Avatar
A single would probably need an hour or so a day depending on your converter output. One of the first things I did was go to a second 12V...and then two 6V when those gave up nearly five years later. Not incredibly expensive and gives you some flexibility.
Old 06-26-2016, 06:55 PM   #6
Flybob's Avatar
Use the generator to power the RV and let the converter charge the batteries rather than use the 12V DC outlet on the generator even if it says something about being a battery charge outlet.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 06-26-2016, 07:00 PM   #7
urocav2001's Avatar
Does the fridge use a lot of battery power while running on propane?
Old 06-26-2016, 07:08 PM   #8
raspivey's Avatar
Very little. Your biggest concerns will be incandescent lighting (LED is much better) and furnace fan.
Old 06-26-2016, 07:10 PM   #9
bikendan's Avatar
Especially the furnace fan.
Old 06-26-2016, 07:13 PM   #10
HONDAMAN174's Avatar
Not really. But get one of these to monitor when you need to charge:
Name:	ImageUploadedByForest River Forums1466986359.263832.jpg
Here is a reference chart:
Name:	ImageUploadedByForest River Forums1466986388.803700.jpg
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
battery, charging
