Old 04-08-2015, 03:19 PM   #11
offroad's Avatar
Originally Posted by Marines0811 View Post
He is a picture of it . It's right under the propane tanks in front of the battery box.
I have the same disconnect on my 8329, I like the placement as well.
Were you plugged into shore power or your tow vehicle when you had lights with the battery disconnect turned off? The converter would give you inside lights if its hooked up to 120V AC.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 04-08-2015, 03:28 PM   #12
Crockett's Avatar
Have a 2015 233s my battery is disconnect is outside by the tongue. It's a red plastic key . I turned it off but sit had power to lights and the slide???
could you have been plugged in at the time?
Crockett is offline   Reply With Quote
Old 04-08-2015, 03:45 PM   #13
Marines0811's Avatar
Probably , don't remember. Lol
Marines0811 is offline   Reply With Quote
Old 04-08-2015, 03:50 PM   #14
Crockett's Avatar
Bingo...dont feel bad, I can never get the water pump to run when the city water is connected.
Old 04-08-2015, 03:54 PM   #15
B47
Originally Posted by bikendan View Post
if that's factory, it's a new thing. i still think that it might be a dealer install, since i haven't seen any other new Roo/Shamrock owner with this switch setup.
Our 2012 SB had the same BD switch - put the key in (attached to the lanyard) and turn to connect the battery. Turn the key to disconnect and remove the key.
Old 04-12-2015, 08:51 PM   #16
wicked1's Avatar
Just picked up our 2015 Too 23IKSS yesterday and battery cutoff is on frame under right propane tank as well with a red key
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 04-13-2015, 05:03 PM   #17
Not a bad thing! Mine is located by the converter and easy to kick off with my foot if not careful.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
Old 04-13-2015, 06:20 PM   #18
Kaadk's Avatar
Also easy for the kids to "what happens when I push this button?".
There's no use crying over spilt milk, unless it's on your keyboard.
Old 04-13-2015, 07:56 PM   #19
wicked1's Avatar
My kids are 22 and 20 want nothing to do with camping
Old 04-13-2015, 09:18 PM   #20
Oh, wheeeere did you go wrong????
2011 Traverse LT, 3.6L, FWD
battery
