Old 05-15-2012, 08:09 PM   #1
Battery drained and not recharging?
I have just purchased a 2000 Shamrock by Forest River, with brand new battery...the LP gas detector started sounding after a few days and now the battery is flat.
What would cause it to drain so quickly?
Why does it not recharge when connected to the mains (shoreline)? Does it have a convertor, can't see it on the a-frame?
Very new to this world and keen to get exploring but have not power...any help for this newbie from South Africa is welcome
kookyinutah is offline   Reply With Quote
Old 05-15-2012, 08:11 PM   #2
TURBS's Avatar
yes you should have a convertor !
if its not working your battery will drain in a few days from parasitic loads .
Old 05-15-2012, 08:13 PM   #3
What is a few days? Was the battery properly charged? When plugged into shore power what is the voltage on the battery? To be charging, it should be around 13V.
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 05-15-2012, 08:23 PM   #4
Triguy's Avatar
Welcome to FRF. Congrats on your new to you trailer. What model do you have?
Maybe we can help.
Parasitic drains on the trailer that are on all the time are the cause, I bet. These include Lp Detector, radio, etc. Depending on the size battery, this can happen in a week or two. A small group 24 will not last long. The cheap solution is to disconnect the neg cable. Or, install a battery disconnect.
The converter maybe under the fridge but not sure with a 2000. You'll find it where the fuses and breakers are located.
Are you getting any power at all to the AC (120 volt) appliances like air conditioning or to the receptacles?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-15-2012, 08:27 PM   #5
Tks for the quick responses...
Do you know where the convertor is? Should I disconnect the battery when not in use?
A few days could be more like 3 weeks thinking about it more. Just plugged it in and the volts are 2.54 (probably cause I hooked up yesterday to see if the car would charge it...prior to that it was 0.52 volts.
Old 05-15-2012, 08:33 PM   #6
Model - 2000 19ft Shamrock pop out
Old 05-15-2012, 08:34 PM   #7
Triguy's Avatar
Can you tell us how you are measuring these and what size battery you have?
Check below the fridge for your converter. I posted earlier but my Internet went Kablooie with this storm we are getting tonight.
Scott
2012 Shamrock 233S
Old 05-15-2012, 08:40 PM   #8
Herk7769's Avatar
You are looking for something like what is on the cover of this manual.
File Type: pdf Manual - Power Distribution Center WF-8900 English.pdf (1.89 MB, 48 views)
HAM CALLSIGN - KC3FFW
Old 05-15-2012, 08:52 PM   #9
Aircon and Microwave are working when plugged in. Can't find a fuse board anywhere, nothing under the fridge either. Closest thing is the white box that tell me about the tanks and battery...
Old 05-15-2012, 08:58 PM   #10
Triguy's Avatar
Try this. Go under the trailer and follow the wire from the positive terminal of your battery to its end point. That will be the area where you will find your converter. The problem is that there aren't too many 2000 Shamrocks on the forum so I don't know in your model.
Scott
2012 Shamrock 233S
battery, expandable, hybrid, led pad, shamrock, converter
