Old 08-09-2014, 10:42 PM   #11
Roocrew1's Avatar
When I'm traveling, it's on. When I'm connected to shore power, it is off. In storage, it is off.
Roocrew1 MI
2012 233S
2010 Expedition EL Limited 3:73 with Air Suspension
Roocrew1 is offline   Reply With Quote
Old 08-10-2014, 06:30 AM   #12
Battery Isolation Switch
I also installed a disconnect switch to use in storage. I made sure the break away switch bypassed the disconnect in case I forgot to turn the switch on when traveling ( or someone turned it off). Could be really dangerous.
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
Old 08-10-2014, 07:07 AM   #13
indybp57's Avatar
Originally Posted by Aussiecat View Post
We have the battery switch on our 23SS next to the fuse breaker box below the fridge,
In is disconnect. Ours is in the same location about 10" off the floor. It kills 12v power to everything even when connected to TV power. On one occassion while traveling a box slid across the floor and pushed it in, and when we got to the campsite our fridge was warm. We have since started using a wireless thermometer so we can monitor fridge temps while travelling. I plan on cutting and slitting a short piece of rubber tubing to slip over the shaft of the disconnect switch to prevent that from happening again.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 08-10-2014, 07:22 AM   #14
bubbles's Avatar
I am not familiar with your set up but some of those type push/pull switches have terminals for normally open and normally closed (depending on actuator position). Have you pulled the switch to check for a set of terminals for the opposite actuation? Just a thought.
Old 08-10-2014, 04:39 PM   #15
indybp57's Avatar
No I have not, but that's not a bad idea. I'll check into it. Thanks.
2013 Roo 183
battery
