Old 08-08-2014, 07:58 PM   #1
Old Fella
Aussiecat's Avatar
Battery Isolation Switch
We have the battery switch on our 23SS next to the fuse breaker box below the fridge, I tried it both pushed in and out and it doesn't seem to make any difference, the lights and fans in the bunk ends still operate either way. I'm guessing that maybe all the 12 volt items are working off the inverter while plugged into shore power.
While camping should this switch be in or out?
While in storage should it be in or out?
Any assistance will be greatly appreciated.
Aussiecat is offline   Reply With Quote
Old 08-08-2014, 08:25 PM   #2
If I remember correctly, out is connect and in is disconnect. ( I think I'll label mine and hope I got it right.)
If on shore power lights will all work since power is from the inverter not the battery, in storage, put the switch in off to disconnect non critical circuits (like inside lights, etc) so that your battery does not run down. I've always turned the switch to on when I camp, but since I only use shore power I'm wondering if I could just leave it in off position. The tongue jack still works and this is all I generally care about. If you leave the switch in connect while in storage you run the risk of a dead battery and having to plug to the TV to operate the power tongue jack.
richl167 is offline   Reply With Quote
Old 08-08-2014, 08:33 PM   #3
Just thought about it... I think you have got to put the switch in connect position while on shore power. Otherwise the inverter will not trickle charge the battery. Guess I'll continue to do as I have been doing !
Old 08-09-2014, 04:26 AM   #4
bikendan's Avatar
it's not an inverter, it's a converter!
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 08-09-2014, 09:02 AM   #5
Old Fella
Aussiecat's Avatar
Can you explain the difference and purpose.
Old 08-09-2014, 09:08 AM   #6
A converter takes 115 volts and converts it to 12 volts to power the camper and charge the battery
An inverter takes 12 volts from the battery and inverts it to 115 volts to to power those devices.
Hope this helps.
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
Old 08-09-2014, 12:28 PM   #7
bikendan's Avatar
Hope this helps.
correct. Plus all RVs come with converters but few come standard with an inverter. Usually class A motorhomes.
Old 08-09-2014, 12:59 PM   #8
NELA
Weezer's Avatar
Sneak made a label for ours:
OUT IS ON
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 08-09-2014, 05:04 PM   #9
Old Fella
Aussiecat's Avatar
Found out today, we weren't out to the storage yard to install the power jack and while it wasn't connected to shore power found that the lights etc. only worked when the switch was out. I guess while you're connected to the power it doesn't matter.
Old 08-09-2014, 05:05 PM   #10
Old Fella
Aussiecat's Avatar
Sorry not weren't, were.
battery
