Old 06-25-2013, 10:33 AM   #1
Battery not charging
I have a 2011 shamrock hybrid 19ft and the battery is dead and not charging! Does anybody have any ideas how to fix this?
Sidney41 is offline   Reply With Quote
Old 06-25-2013, 10:35 AM   #2
I also put a new battery in and it did not work! Is this a wiring issue?
Old 06-25-2013, 10:35 AM   #3
TURBS's Avatar
Sounds like you need to do some troubleshooting.
You also need to remove battery and charge it back up to full and have it tested.
Do you have a wfco converter/ distribution panel
Do you have a digital multi meter?
Welcome to the forum
Turbs
Old 06-25-2013, 07:50 PM   #4
Stormrider151's Avatar
I had the same problem while towing. Come to find out the hot wire from the truck was dead. It was a new truck and there were two fuses in the glove box that needed to be installed. Works great now.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 06-25-2013, 09:12 PM   #5
Dave_Monica's Avatar
You'll need to provide more information. Is any of the 12V lights/devices working when on shorepower? Do you have a battery disconnect switch? Have you checked for a blown in-line fuse or tripped in-line circuit breaker on the +ve wire from the battery?
Dave
Old 07-10-2013, 12:04 AM   #6
I have a fully charged battery and it will not power anything-power works when the camper is plugged in-tonite i checked the wiring underneath and all looks good-cu it be something else like the emergency brake circuit not working and hence not allowing power to draw into the camper?
Old 07-10-2013, 02:41 AM   #7
bikendan's Avatar
look for the infamous silver resettable breaker/fuse. it's along the A-frame, between the battery and the front of the trailer.
there's a little black reset button on it.
when someone installs the battery and crosses the battery wires, it sets this breaker/fuse off.
just Google "resettable 12v breaker/fuse" if you want a pic of one.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-10-2013, 06:52 AM   #8
TURBS's Avatar
This
Old 09-06-2013, 06:29 PM   #9
I had the problem of the battery not charging and even with the 23SS plugged in I had to connect a power pack or battery charger to get the slide to work. Three times the dealer checked and told me that everything was OK. It wasn't. When I looked for the "infamous resettable fuse" I found that one of the terminal nuts was missing, one wire was completely off and a second was probably making intermittent contact. Put the wires back on the terminal replaced the missing nut and had no problems since!
Robin and Gloria Vinson
Montreal, QC, Canada
2010 F-150 SuperCrew XLT 4x4
2012 Shamrock 23SS
47leaf is offline   Reply With Quote
expandable, hybrid, shamrock
