Old 03-16-2012, 09:11 PM   #1
Athens-M50's Avatar
Battery Pos. side cut????
******Cross posted:*****
ok....so I have had our camper a year......Hybird Shamrock 2002 model.....I knew it did not have a battery on it....so I thought I might buy one and put on there....to have when we are not connected to AC....Lights and such.....so I pulled the cover off the gas tanks...and the connector on the Pos. side of the cable has been cut off???????.......hummmmmm....why?
I can put another on easy......but why was it cut ....makes me think something might be wrong?????......how can I find out?
guess just get one and hook a Battery up and see what smokes
is if common if there is a issue to CUT the cable?.....or did he need the battery and did not have time to remove the lug.....and just cut the wire?
any thoughts???
Thanks,
Athens
2002 17' Shamrock
2001 F150 Ext Cab
________________
2012 nights camped 6
Athens-M50 is offline   Reply With Quote
Old 03-16-2012, 09:16 PM   #2
Full time RV'er
Bradrustan's Avatar
The terminal may have been corroded so bad it had to be cut. I had a car do that once and had to replace it. Try putting on a new one and see what happens. If something is bad wrong it will spark bad right at first. Not a bad idea to have fire extinguisher on hand too.. Good luck
Bradrustan is offline   Reply With Quote
Old 03-16-2012, 09:41 PM   #3
Triguy's Avatar
Besides having a battery to supply power when you are not on AC, your trailer's electric brakes require it when towing. Your emergency brakes will not work without a battery (need power for the breakaway switch).
Good idea to get one on there.
I can't think of a reason to cut it off unless it was corroded.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-17-2012, 12:44 AM   #4
bikendan's Avatar
yep, you're breaking the law by transporting the trailer without a battery, since it has electric brakes.
maybe someone stole the battery and cut the wires to take it quickly.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-17-2012, 06:24 AM   #5
Athens-M50's Avatar
@bikeadan
Have not thought of that....may have stole it.....
2002 17' Shamrock
2001 F150 Ext Cab
________________
Old 03-17-2012, 07:42 AM   #6
Taranwanderer's Avatar
Unfortunately, that was my first thought as well.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
battery, expandable, hybrid, shamrock
