Old 06-29-2015, 10:19 AM   #11
7 Year Class A RV'er
The box in your cab controls the amount the brakes are applied, proportional to what you are applying and the setting you have on the controller. The breakaway device has to have it's own battery that will activate the brakes if everything else disconnects from the tow vehicle.
2015 Legacy SR340 360RB
Old 06-29-2015, 10:35 AM   #12
TURBS's Avatar
You have to have a battery.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 06-29-2015, 11:02 AM   #13
cogito ergo moo
Cowracer's Avatar
The thing that usually makes a battery hiss and smoke like that is a over-voltage on the charging system. If you have a volt meter, check the battery voltage when plugged into the shoreline. Your current battery is toast, but you want to make sure your new one doesn't get fried too.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 06-29-2015, 11:03 AM   #14
TURBS's Avatar
Most likely another junk wfco converter.
Progressive dynamics should be your first purchase with a new battery.
TURBS
2011 32bhok Sabre
Old 06-29-2015, 11:09 AM   #15
Thank you guys.
jscraig is offline   Reply With Quote
Old 06-29-2015, 12:16 PM   #16
mike.t's Avatar
Disconnect the battery if you are going to store the RV. A few day's before your going to use it connect it and let it charge back up. Always check the water. And don't read to much in to most "Maintenance free batteries" you can still put water in most.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 06-29-2015, 01:41 PM   #17
camaraderie's Avatar
It could easily be a short in the battery...instead of a blown converter. I'd hook up a new batt and take voltage readings at the terminals:
1. Before installing
2. 5-10 min after installing AND plugged into 30amp.
3. 4-5 hours after installing.
Your readings should be
1. 12.6-.7 Volts.
2. 14+ volts...not more than 14.6 or disconnect immediately. You have a converter problem.
3. Between 13.2 and 13.6V ...if higher...get a new converter.
If all the readings are in range, problem solved..keep the water up and don't run em down past 50% discharge. Good luck.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 06-29-2015, 04:22 PM   #18
Please do not use that battery. Be safe.
labarn
labarn is offline   Reply With Quote
Old 06-29-2015, 08:29 PM   #19
Tom48's Avatar
Some trailers seem to come with a ONE SIZE FITS ALL "CHEAP" converter charger. Upgrading is never bad but at least during storage pull the battery terminal off and put a GOOD HIGH END battery maintainer on it. The best Converter Chargers top the battery 80 % at a higher voltage then drop down a few tenths of a volt to top the batterys off and finally go to a trickle charge or maintainer voltage that should not BOIL the batteries. Then the really good ones have a cycle that periodically soups up the voltage and knocks the sulfur build up off the plates without BOILING them and that evidently helps them last a lot longer
Tom48 is offline   Reply With Quote
Old 06-29-2015, 08:40 PM   #20
mike.t's Avatar
Tom. So you don't recommend disconnecting the battery during storage? Just asking. How about mineral oil in the battery to help stop evaporation?
2015 Salem 27RKSS
55' Chevy Bel-Air
battery
