Old 10-23-2011, 12:50 PM   #21
TURBS's Avatar
Old 10-23-2011, 01:08 PM   #22
Triguy's Avatar
Originally Posted by biken201
I don't have a power tongue lift, so I can't speak to that; but the slide still operates with the battery disconnect killing power to everything else.
Thanks. Even still, it's great that they are installing a disconnect. This is the first time I've ever seen one standard on a hybrid.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-23-2011, 02:31 PM   #23
bikendan's Avatar
yep, that's a great feature to have in a hybrid. wonder why this is the first i've heard of it.
must be a mid-season upgrade.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-23-2011, 03:04 PM   #24
Ok folks, here is the answer you have all been waiting for......Push in to kill the power and pull out to energize the power. Ta Da.
In responce to those of you who have the kill switch down stream of your power slides and tongue...the obvious answer is that those two devises cannot be left in the on position and drain your battery. The power slide has an end of travel disconnect switch on the motor, so you can't slide the sucker right out on the ground... and the tongue has a similar devise to prevent the permanent wheelie.
Problem solved, thanks to everyone who had input, much appreciated.
Roopert21bh is offline   Reply With Quote
Old 10-23-2011, 03:38 PM   #25
TURBS's Avatar
I guess what we were discussing was whether or not slides and power jack work with switch in the off position?
battery
