Old 10-22-2011, 06:05 PM   #1
Battery Switch
Does it disconnect the battery when you pull out or push in the switch?
Roopert21bh is offline   Reply With Quote
Old 10-22-2011, 06:09 PM   #2
Boyd's Avatar
I think a picture would help out here.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 10-22-2011, 06:21 PM   #3
TURBS's Avatar
might have to stick a volt meter on the terminals to be sure .
otherwise turn on lights in camper then push button or pull it to see when the turn off .
Old 10-22-2011, 06:26 PM   #4
bikendan's Avatar
i think you need to give us more info. what switch are you talking about? like was said, a pic is worth a thousand words.
Roo hybrids don't have a battery disconnect switch unless you installed it or the previous owner did.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-22-2011, 07:07 PM   #5
The switch in our 2012 Roo 183 (brand new) is located below the fridge, a little silver knob, push/pull affair. I tried the trick of leaving the lights on and activating the switch, but I guess when the trailer is plugged in, the converter is giving the system 12-13 volts dc. I wish they would put a wiring diagram for the whole trailer. Oh well
Old 10-22-2011, 07:23 PM   #6
TURBS's Avatar
true if its plugged in the lights will stay lit !
you have to unplug it
Old 10-22-2011, 07:26 PM   #7
bikendan's Avatar
i looked at some pics/videos of the 2012 183 and i did see a round silver thing on the front of the converter/breaker/fuse panel's cover.
is that what you're talking about?
if so, i've never seen that on any Roo/Shamrock. didn't they tell you in the walkthrough what it did or what it was for?
the converter's manual should have some info what it's for.
Old 10-22-2011, 07:31 PM   #8
No, this silver knob is about 6-12 inches away from the converter, but on the same level. It's definitly a battery kill switch, i just need to figure out which position does what.
Old 10-22-2011, 07:46 PM   #9
Triguy's Avatar
I've got a 2012. Must be something new with the 2012 1/2's because mine doesn't have this.
And, why would they put a disconnect so far away from the battery?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-22-2011, 07:51 PM   #10
Well, as far as so far away from the battery.... it is right beside the converter and it is inside out of the elements. All they had to do was break the lines coming into the converter......Maybe
battery
