Old 11-06-2015, 10:06 AM   #11
Mr Haver, I am leaning toward your thoughts as well. I did see the silicone blob in the corner but not the length of the interface back to the camper hinge.
The storm was an extreme test for sure, but great to find out on the first camp out.
Plato, thanks again
Curry's
2014 ROO 24 IKSS
2012 F150 Quad Cab Eco Boost short bed w/tow package
fyrdad is offline   Reply With Quote
Old 11-06-2015, 10:12 AM   #12
I had the dealer install guttering over both bunk ends on my 23ikss. However , I don't think that would help you in this instance. Looks to me that water entered along the white channel. Chances are the camper was not perfectly level (almost impossible to do) and that area was the low spot. I would suggest sealing along the channel and hosing it down when you get home. While you're at it , take the time to inspect and condition the rubber seals around the bunks. Probably wouldn't have helped this time but will save you trouble down the road. Good luck.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 11-06-2015, 10:20 AM   #13
Platokidd's Avatar
Yes I would agree, just throwing it out there as a add on.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 11-06-2015, 10:31 AM   #14
What gutter did they install? Standard RV gutter rail with the vinyl snap insert?
Mr Havercamp is offline   Reply With Quote
Old 11-06-2015, 06:41 PM   #15
I don't have the camper at home now but as I recall, it is a u channel running the width of the bunks with mini downspouts on each end. I posted pictures on here some time ago and I have searched in vain to find the post. If I find it I will repost. Just found pictures.
ID:	93830   Click image for larger version
Jim and Deb
2013 Ram 1500
bed, leak
