Old 11-06-2015, 07:31 AM   #1
Bed leak
Morning all, I purchased my sister in laws '14 24 Roo IKSS. First time out at hunt camp. We had a huge storm come thru last night. Slight water leak on one side of the bed. The other two side were dry. So have the fan running on the mattress that got a little damp. I'll point it out. Thanks
Any suggestions on
1. How to locate the source?
2. How to stop it?
Name:	ImageUploadedByForest River Forums1446816665.961171.jpg
Curry's
2014 ROO 24 IKSS
2012 F150 Quad Cab Eco Boost short bed w/tow package
fyrdad is offline   Reply With Quote
Old 11-06-2015, 07:38 AM   #2
Platokidd's Avatar
Campdry
http://www.amazon.com/s/?ie=UTF8&key...l_1aon98gjnr_b
Or is the leak by the end seals?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is online now   Reply With Quote
Old 11-06-2015, 08:14 AM   #3
jeff64's Avatar
Back when we were tenters they made a product called seam sealer that you put over the sewn seam and it wicked in. The camp dry may do the trick too. Are your tent ends vinyl or canvass. I would assume the top and beltline to be vinyl. You sure it's a water leakage and not just condensation? Condensation is a pretty common thing in pups and hybrids. You have to leave a vent open and a circulating fan on to minimize it. Used to get it big time on the support rods and bottom of the roof tents. Cold weather, raining, heat on and 2-3 people breathing makes a lot of humidity condensing out on a cold surface
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 11-06-2015, 08:28 AM   #4
Morning, great suggestions, we had a huge storm come thru, rained for 6 hours or so, at times torrential downpour.
I too tent camped. Have used seam sealer before. The leak doesn't seem to be originating from the seams. Seams are all dry.
It looks and feels like it is coming from under that white strip along the edge of the bedClick image for larger version
Name:	ImageUploadedByForest River Forums1446819922.446236.jpg
Where I am pointing to.
I'm thinking the water seeped in along that edge. Thinking of getting some type of sealer for the outside
As far as condensation, I'm pretty sure I can rule that out. It was to concentrated in one area. I have had that happen in my old Palamino and totally agree
Curry's
2014 ROO 24 IKSS
Old 11-06-2015, 08:37 AM   #5
Platokidd's Avatar
Is it puddling in that area outside?? Seam sealer / campdry and go over the whole darn thing . Wait awhile, then hose her down n check leaks.
While your at it , check for mildew on the canvas. This would be a warning sign of areas that water seeps in when closed.
Treat the seals to the bed area (303 aerospace).
Bed ends can be a water problem area on the hybrids.
nights of camping
Seasonal
Old 11-06-2015, 08:52 AM   #6
jeff64's Avatar
You are kinda alluding to a capillary action type thing. I know water can run up hill to some extent on roofs. I'm assuming there is some type of bungee cord setup on the tent end to connect to the platform. Looks like your sidewalls are canvas and the lower belt is some rubberized type of material. Had a pup made both ways and the hybrid was made this way to to prevent rot. Is this the end your head is at only or is the foot end of the bunk the same way with the leakage? If not, I still got to go with the condensation theory
14K Equalizer
Old 11-06-2015, 09:16 AM   #7
Plato: no puddling but on closer look, there is some discoloration .
I'll have to check into this more obviously.
Camp dry and sealer on the list of "must buy"Click image for larger version
Name:	ImageUploadedByForest River Forums1446823011.478613.jpg
This was the foot end of the bed.
Curry's
2014 ROO 24 IKSS
Old 11-06-2015, 09:40 AM   #8
Forget sealers and 303 and mildew etc.
Stupid design. They eliminated the tent flap that overhung the door edge when open, so it would make it easier to not get fabric in the door when closing. It created this problem. The water had to be getting in the seam at yellow arrow between the tent fabric and door edge aluminum channel, and most likely a wind driven rain. On the 2016's I looked at, they caulked the corner area shown by the white arrow with clear silicone for some reason, but no caulking the rest of the way back the seam between tent and door. They are counting on the tenting being snapped into the plastic snap channel you point to in your picture to be the seal. It is one of the things I will be looking at hard when our 23WS we have ordered comes in. A small bead of clear silicone in that gap is probably a good idea.
Mr Havercamp is offline   Reply With Quote
Old 11-06-2015, 09:40 AM   #9
Platokidd's Avatar
Would clean that with some sort of mildew cleaner and re-treat.
Check the forum, think I read awhile back that some folks even made pvc gutters and attached to their units when closed.
nights of camping
Seasonal
Old 11-06-2015, 09:45 AM   #10
Platokidd's Avatar
Bunk end water fix...cheap!
PVC Gutter
nights of camping
Seasonal
bed, leak
