Old 06-05-2015, 10:30 AM   #1
Old Ram Guy
Avenger61's Avatar
Bent Axles?
I was under my Shamrock 23IKSS last weekend installing the SteadyFast stabilizers and happened to notice that my axles look a little bowed in the middle. I have had this trailer out at least a dozen times since I bought it last year and never noticed any vibration or problems at all. Is this normally how they look? I'll try to get a picture between rain storms.
Marty, Jenice and DD
2019 Entegra Odyssey 29V
Avenger61 is offline   Reply With Quote
Old 06-05-2015, 10:36 AM   #2
BBBlue's Avatar
I believe they are all bowed by design.
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
BBBlue is offline   Reply With Quote
Old 06-05-2015, 10:37 AM   #3
Axle Bow
They should have some bow to them. The thought being when they are loaded with additional weight they will straighten out to some degree. Of course more weight, more straight. I could never figure out how all that affects how the tire rides. My tires were wearing unevenly and I had the axles adjusted (actually bent back into spec), put on new tires and so far after 2000 miles all is well. Best thing to do is measure and track tire wear every 1000 miles. I looked at wear and measured depth in three places on each tire and recored the data.....
Hope that helps some.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 06-05-2015, 10:52 AM   #4
Old Ram Guy
Avenger61's Avatar
Yeah it's not a lot and you really don't notice it unless you are looking for it. I never noticed it anyway; actually my 14 year old Son noticed it first! I swear the boy has a knack for finding problems for me to worry about and fix, but he can't see dirt in his bathroom to save his life!!
Old 06-05-2015, 10:59 AM   #5
Old Ram Guy
Avenger61's Avatar
Here is a picture if I uploaded it correctly.
Old 06-05-2015, 11:03 AM   #6
No picture!!!! If you are concerned place a 4 foot straight edge, I use a 4 foot level across the bow and measure the bow in the center. If it is a Lippert frame they have a spec for the bow.
Old 06-05-2015, 11:04 AM   #7
Old Ram Guy
Avenger61's Avatar
Second attempt
ID:	79096   Click image for larger version
ID:	79097   Click image for larger version
Old 06-05-2015, 11:05 AM   #8
Old Ram Guy
Avenger61's Avatar
Great idea, I'll try that. Thanks!!
Old 06-05-2015, 11:14 AM   #9
Here is a picture of one of my axles. I think I had 1/8 inch on one and 1/4 on the other. Might also want to weigh your rig at some point. I did that after two years and could not believe how heavy my hitch weight was.
Name:	Rear Axle 1 (4).jpg
Old 06-05-2015, 11:35 AM   #10
Old Ram Guy
Avenger61's Avatar
Will do; thanks for the great info David.
Old 06-05-2015, 04:14 PM   #11
Hicks43's Avatar
It is normal to have a bend in them it's for camber
Hicks43 is offline   Reply With Quote
Old 06-05-2015, 08:52 PM   #12
The axle on our 23IKSS has a slight bow also, this in normal. Have you used your camper yet since you installed the steadyfast stabilizer system? We have used ours 3 times since I installed them on ours and what a difference it makes. The only thing I have to remember to do is loosen the clamps when cranking the stabilizers up and down. On our last trip I forgot to loosen the clamp on the one to the rear of the camper and could not figure out why the stabilizer cranked down harder than normal. Once I remembered that I had not loosened the clamp and then done so it worked much better. I think the stabilizer system was worth the money spent on it.
RCCS is offline   Reply With Quote
Old 06-05-2015, 09:09 PM   #13
67cudafb's Avatar
How is tire wear? If wearing even then I wouldn't be concerned.
1967 Barracuda fastback
2015 Wildcat MK 333
2010 Ram 2500 Mega-cab
67cudafb is offline   Reply With Quote
axle, bent
