Old 10-03-2014, 10:27 AM   #11
Flagstaffer06's Avatar
I made a spray bottle of just about 50/50 water to bleach. I used it as a recommendation from someone on my forum for some stubborn stains on the roof. I tried it one day on the white latches and some trim and it came out new. I spray it on, let it sit for a few minutes and then hose off and rinse well. I was careful not to get it on anything other than the latches as best as possible.
2012 Keystone Sprinter
Still sticking around for the good people and advice.
Flagstaffer06 is offline   Reply With Quote
Old 10-03-2014, 04:51 PM   #12
indybp57's Avatar
It must be some type of mold or you bleached out whatever pigmentation was there. Just an FYI if you use bleach too frequently it will eventually start eating up the plastic. I would cut back my concentration to 10% and see if that still gets the job done.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 10-04-2014, 08:16 AM   #13
I was thinking that maybe Oxyclean might work. Might be milder then the bleach.
syogerst is offline   Reply With Quote
Old 10-05-2014, 04:12 PM   #14
Out of Oxyclean, used it all on the roof. Tried 50/50 bleach, really did not show very much results. Then the test was, is this something on the surface, or in the plastic. Tried a little area with strait bleach. This is the result.Click image for larger version
Name:	ImageUploadedByForest River Forums1412543295.426454.jpg
ID:	64163 Clean!! Other than the labor intensive cleaning, what should I put on the plastic to protect it from degrading?
Nccamper is offline   Reply With Quote
Old 10-05-2014, 08:37 PM   #15
indybp57's Avatar
Kind of looks like the same mildew you see on vinyl siding and fiberglass that has no sun exposure. You might try some sort of UV protectant like Armor-all or something similar. Maybe even a spray on auto wax. The idea would be to apply a coating that would seal out oxygen and moisture.
2013 Roo 183
Old 10-05-2014, 09:20 PM   #16
The plastic gets brittle and sun damaged. I cleaned mine last year with Simple Green and a Magic Eraser, then with 303 UV spray...
2008 Forest River Micro-Lite 18FBR
2000 Ford Explorer Sports Trac
WBrian is offline   Reply With Quote
Old 10-05-2014, 10:22 PM   #17
Thanks! As soon as I get it all clean, the UV protectant is going on.
