Old 07-22-2016, 05:20 PM   #11
Originally Posted by rockfordroo View Post
Yeah, that's the THEORY! But in practice, they still flap.
There's no flapping with mine.....Even if it flaps in your neck of the wood, does it keep you awake at night !!!
I'm trying to understand what's the big deal if they flap !
Drenjoey is offline   Reply With Quote
Old 07-22-2016, 06:06 PM   #12
Because that's what ends up making it loose enough that the tennis balls fall off the gutter spouts. My thoughts for next year are to run a rope around the top, just under the spouts; hope this will keep it tight enough at the spouts that the balls can't come off.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 07-23-2016, 07:04 AM   #13
bareftn's Avatar
I don't have a flap with mine their are many ways to take care of it , as far as the balls falling of I don't use then I take a swimmers noodle cut down to about 8 in and make a split down one side for all spouts and any place that will be a wear point and zip tie them. I place a large rubber mat over the tv antenna and then when that is done I place a large blue tarp over the over cover the adco cover and use several ropes to go all the way over and under the camper and ties them off so no flapping just very little to let wind under to keep it dry.
bareftn is offline   Reply With Quote
Old 07-25-2016, 02:43 PM   #14
Old Eeyore's Avatar
So whatever you get, you need to figure out a way to keep the tennis balls on the drip spouts. I haven't figured it out yet.
I had similar problems with the tennis balls and decided to give swim noodles a try. I cut them a 1 1/2" longer than the spout, slipped them on then put the cover on. Three winters with no problems. . .
Also used an ADCO for 6 years. Had no problem with flapping. But I probably didn't have as much extra on the ends as other folks as I pulled the cover over the spare tire and the propane tanks. That took up a lot of the extra material - and the straps did the rest.
2016 Roo 23IKSS / 2011 Tahoe
2011 Roo 21SS / 2011 Tahoe
2006 Bayside / 2006 4Runner
1999 SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
Old Eeyore is offline   Reply With Quote
Old 08-03-2016, 09:27 PM   #15
Thanks very much for your replies about the Adco. Which type of Adco do you all have in snowy climates? Designer Tyvek or Sunbrella?
mrc1012 is offline   Reply With Quote
Old 08-03-2016, 10:08 PM   #16
Here's what I have for my Mini Lite in northern Illinois (48" of snow last year, only about 2 ft this year):
ADCO All Climate + Wind Designer Tyvek RV Cover Travel Trailer, 22'1" - 24'
cover, rockwood, rockwood roo, roo
