Old 06-06-2012, 01:46 PM   #1
dawg82's Avatar
Black water tank
So I am the new owner of a 2011 Shamrock 21ss and was wanting to know any tips or tricks to get all of the water out of the black water tank.I can get most of it out but there is still a little left in the tank after draining.Any help would be much appreciated.
dawg82 is offline   Reply With Quote
Old 06-06-2012, 01:59 PM   #2
TURBS's Avatar
Should never drain it dry.
Read "great tip " thread
Also if your reading your tank indicators and it says there's still waste in the tank do not trust them.
They are inaccurate at best.
Old 06-06-2012, 03:02 PM   #3
Herk7769's Avatar
http://www.forestriverforums.com/for...ion-16089.html
Will explain what is going on and the "Fix."
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 06-06-2012, 09:46 PM   #4
bikendan's Avatar
you should NEVER leave a black tank dry.
after you dump, you should be putting 3-5 gallons back in it as soon as possible.
otherwise, you'll have stuff that will harden and never leave the tank.
Old 06-07-2012, 09:53 AM   #5
TURBS's Avatar
Or grow! Lol
Old 06-03-2013, 06:48 AM   #6
TURBS's Avatar
Originally Posted by Sshultz64 View Post
Question, after emptying the black and gray tank from my camper, the indicator for the black tank still showed 1/3 full. I flushed it out the best I could at the dump station, and even got under neath to knock anything loose. It is a fairly new camper, got it this spring, only been out only a few times. Could the indicator be stuck or something? Is there a way to reset it? I see that the suggestion I should keep some water in there? Is it too late for me now? Thanks to all
Search geo method here on frf .
Search horst probes here on frf.
Turbs
Old 08-18-2013, 11:30 PM   #7
Black Water tank
To make sure I get mine empty, I use couple of leveling blocks and lopside the trailer on the one side, then dump it. I also throw in several gallons of water before I go to dump it. Learned this the hard way. I believe when they say not leave it dry, but they're not that bloody big, so I don't want to leave two or three gallons in it. But, I also use an RV tank cleaning wand every few weeks and give it a good spray inside.
Mike & Sharron LeBlanc
2014 ford f150 fx4 ecoboost
2014 Shasta Breeze/Flyte 255RS
Mikeg is offline   Reply With Quote
Old 08-19-2013, 07:26 AM   #8
we just used out mini light for the 3rd trip and noticed the black and grey is reversed on the panel inside the rv. was rinsing tank and wanted to fill it to capacity. kept watching the read out and it kept showing empty. just so happened to hit the button for the grey tank and it showed full. After dumping black tank the read out for the grey showed empty.
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
https://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 08-22-2013, 05:46 PM   #9
Herk7769's Avatar
Depending on how your tank or tanks are oriented, this might be a bad idea.
In our 5th wheel the drain outlet is on the left side, but the tanks face towards the back of the camper.
Tilting our camper to the side would leave several gallons of liquid and lots of solids behind.
In fact, our best option is to raise the nose, but since that would mean disconnecting, a level dump works best.
If you have a galley tank, it can even be oriented different that the black tank.
That could make your technique worse (or better) depending on that tank's orientation to the other two.
ID:	38443   Click image for larger version
black water, expandable, hybrid, led pad, shamrock
