02-08-2017, 12:30 PM
Brakes
Can anyone fill me in on the brakes for a 21ss? Thanks
02-08-2017, 01:47 PM
What do you want to know?
They are electric drum brakes that require a brake controller to function.
02-08-2017, 02:53 PM
Boondocking Only
Yes what Bikendan said.
Easy Lube Axles and Nev-R-Adjust Brakes, electric drum brakes. May be different for other years but this is what my 2014 has.
2014 Shamrock/Roo 21SSL
Complete LED Lighting
Off Road Package
2010 F250 Lariat 6.8 V-10 w/Timbren SES
Custom Tunes by 5 Star Tuning
Boondocking Only
02-08-2017, 02:57 PM
They are used for stopping!
Seriously... Tell us what you want to know about them and many will be glad to help answer your questions.
02-08-2017, 06:03 PM
As previously stated, you will need a brake controller, no big deal using the, just read the directions and learn how to set it up to your liking.
The Roo/shamrock brakes seem to work very well while towing and seem to be nicely engineered.
Once you get them all set up you will forget the trailer has brakes and you just drive.
2016 Shamrock 23WS
2018 F150 Ecoboost
02-13-2017, 11:05 AM
Thanks for the help. Do new trailers come with a break controller?
02-13-2017, 11:20 AM
No, the towing vehicle needs a brake controller as example below, aftermarket installation required......unless you already have an integrated brake controller in your vehicle....
Tekonsha - Trailer Brake Control - Proportional
Fonzie
02-13-2017, 12:38 PM
As fonzie said, your tow vehicle is where the brake controller goes.
And the vehicle has to have the factory tow package, in order to install one
You need to post what your tow vehicle is and its specs. Also if it has factory tow package.
02-13-2017, 08:56 PM
True if you want plug and play. But you can wire one just about into any vehicle if you don't mind doing the wiring yourself.
2011 Traverse LT, 3.6L, FWD
02-13-2017, 09:26 PM
Most newer trucks come with brake controllers, but you can search you tube for instructions on how to install on any vehicle
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
02-14-2017, 11:14 AM
Thanks again, I have a 2013 Toyota tundra 4x4 trd . it has a tow/haul switch.What else do I need ? Sorry Im new to this. I have always had pop ups and didn't worry about this.
02-14-2017, 12:01 PM
Well, you need to confirm that it has the factory tow package. Since it has the tow/haul switch, it probably does.
As far as I know, the Tundra doesn't come with a factory brake controller.
You'll need a WDH with sway control.
02-14-2017, 12:16 PM
Here are the Etrailer.com brake controllers that fit your Tundra. They all say they are for "factory 7-way" or "factory 4-flat".
2013 Toyota Tundra Brake Controller | etrailer.com
Looking at a 2013 Tundra brochure, it looks like the tow package (including brake control pre-wire) is standard on the Regular Tundra, double cab Limited, and CrewMax Limited and Platinum. It says it was "available as part of a package" on the double cab Tundra and CrewMax Tundra, but I couldn't figure out which package.
You also have a tow/haul switch. So there's a very good chance you have the pre-wire for the brake controller.
In any case, click on the first one (for example) and scroll down and there will be a video on how to install it. It should show where the under dash connector is located. You can then look under your dash and see if you have it.
I used the P3 Prodigy on my 2009 Silverado. Worked great.
Good luck.
02-14-2017, 02:55 PM
I have a Wireless Brake Controller.
It works very well, you don't need to mess with the tow vehicle to install it and if you change your tow vehicle you can take it with you easily.
https://www.etrailer.com/Brake-Contr...sha/90250.html
2018 F150 XLT V8 HDPP
2018 Rockwood 2909WS
" Life is simpler when you plow around the stump..."
02-14-2017, 03:09 PM
Insert witty title here
I had a 2015 Tundra before getting my Chevy.
If yours is like mine, there is a connector affixed up underneath the dash just to the right of the steering column. When you buy your brake controller, you need to get a wiring harness specific to a 2013 Tundra which will allow you to connect the controller to the aforementioned connector. Then all that's left to do is attach it to the dash per the manufacturers instructions.
I had a Tekonsha P3 Prodigy which had to be mounted so it faced parallel with the motion of the vehicle. I mounted it low on the dash, just above my right knee but high enough so I didn't hit it.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
