Old 10-30-2015, 10:34 AM   #11
Originally Posted by bikendan View Post
This is the Roo/Shamrock Hybrid TT section and they don't have self adjusting brakes, as far as I know.
You should post in the Rockwood TT/5th section.
The 2015's and 2016's supposedly have Dexter Never adjusts as per both of the brochures.
Ebcobra, I was never able to get a 2011 Aerolite 185, same plan as a Roo 19, to lock up. Tandem non self adjusting dexters 10 X 2 1/4. And that was with either a P2 prodigy or factory GM brake control. The brakes were not screwed up.
I have never been able to lock up the brakes on our current Keystone Passport 235 hybrid, not surprising as it has two 3000 lbs axles with 10 X 1/1/2 brakes thanks to Keystone's penny pinching. But even then the brakes are fully operational.
If you can get them to lock they will need to be hot, you'll never get them to do it cold.
Also check the gauge of wire used from connector to wheels and especially from wheel through axle to opposite wheel. There is a certain gauge wire they recommend. I know someone who had a trailer where they ran a much lighter gauge wire through to the opposing wheel than recommended by Dexter. It caused the shoes to wear on one side faster than the other. I imagine that could be a huge issue from connector to all 4 wheels.
Not designed to be primary brakes only supplemental and you can only get so much friction out of magnets when your talking this much mass.
Mr Havercamp is offline   Reply With Quote
Old 10-30-2015, 10:42 AM   #12
Havercamp, Thanks for the information. I posted this question about a month ago and all of the responses suggested that the brakes were not working as they should. My thoughts are that they are probably working as well as they can. They do grab hard, just never enough for the lockup that's mentioned in the brake controller set up guide.
Just to be sure (peace of mind), I will get them looked at in the spring, but I'm thinking that they are working normally.
Eric & Abby
2016 Rockwood Roo 183
2014 Ford Explorer Sport
ebcobra93 is offline   Reply With Quote
Old 10-30-2015, 10:43 AM   #13
TURBS's Avatar
Originally Posted by urocav2001 View Post
Thinking they are junk too, I will give them a few more tries. Dealer said they could just remove the auto adjusters and put manual ones in place.
You can "still" manually adjust auto adjusting brakes.
Old 10-30-2015, 10:49 AM   #14
TURBS's Avatar
Try backing your camper up in a parking lot and use your brake controller manual apply lever to apply your trailer brakes.
Do this to hopefully adjust as well.
Old 10-30-2015, 10:52 AM   #15
From Dexter;
"""Note: Not all trailer brakes are capable of wheel lockup. Loading
conditions, brake type, wheel and tire size can all affect whether
a brake can lock. It is not generally considered desirable to lock
up the brakes and slide the tires. This can cause unwanted flat
spotting of the tires and could also result in a loss of control."""
Old 10-30-2015, 10:54 AM   #16
Supposedly the Dexter Never adjusts also adjust while applying them moving forward.
That was not the case on my 1974 4 door Ford Maverick chick magnet which only adjusted the drum brakes in reverse.
Old 10-30-2015, 04:21 PM   #17
urocav2001's Avatar
The dealer said try and go backwards and apply brakes but did not make any difference, crappy idea for brakes
urocav2001 is offline   Reply With Quote
Old 10-30-2015, 04:23 PM   #18
urocav2001's Avatar
How can you manually adjust auto adjust brakes? My dealer took apart and showed me how they are suppose to operate and said the only way to adjust manually is to remove the auto adjuster and place a manual one in
Old 10-30-2015, 04:33 PM   #19
TURBS's Avatar
Your dealer is an idiot.
Never adjust brakes still have a star wheel and access hole to adjust them.
As seen below.
Old 10-30-2015, 04:35 PM   #20
TURBS's Avatar
closer view.
brakes
