Old 08-02-2014, 12:24 PM   #11
I am looking into a similar issue on my Jayco 23B. I found a pretty close match in stock at Windsor Plywood. The stuff was about $35 per sheet, and had matching batten style molding like you show in your picture to cover the seams. Unfortunately I see the closest Windsor store to your location is Thunder Bay!
I also found similar material at our local RV store in their giant desk catalog. Unfortunately they were quoting ~$90 per sheet, but sounded like they could get it. No samples in stock though, so can't really assess the match to your existing material. It was the RV store parts rep that put me on to Windsor.
I think the material to look for is called 1/8" luan (or lauan) plywood; we usually call it mahogany ply in the Great White North, but luan / lauan is a common term in the 'States. There is a line of this board in 4' x 8' sheets with the headliner material attached (in various colours and textures). Try a really good plywood supplier in your area; I didn't see this at Home Depot or similar.
Not sure of your roof construction details, but mine is the typical luan and Styrofoam vacuum formed panel. For the repair, I was going to use water based contact cement, that is compatible with Styrofoam. Jon Eakes recommends LePage Pres-Tite Green for this application.
What glue will stick to what?
https://www.amresupply.com/part/0165...RN-CONTACT-CEM
Couple of other thoughts. Was going to use this type of saw to cut the existing paneling if I could get away with a patch
http://www.homedepot.ca/product/rotozip-zipsaw/969113
The RV tech that looked at our roof & ceiling used one of these to determine how far the moisture has spread behind the head liner material. It was wet over a considerably larger area than the apparent wrinkling. I also thought this tool would be good to assess when the roof structure was adequately dried out prior to installing new material.
http://www.homedepot.ca/product/digi...display/835218
Haven't done the job yet; just trying to figure out the scope and see if I can DIY or need the whole roof removed.
HTH
Stu
2006 Jayco 23B
stugilmour is offline   Reply With Quote
Old 09-07-2014, 12:26 PM   #12
coryhynes's Avatar
Update. Finally got around to looking at my roof a little closer. And of course I had the dreaded mold. So looks like I had to replace my interior roof. I
Sent from my Nexus 4 using Forest River Forums mobile app
coryhynes is offline   Reply With Quote
Old 09-07-2014, 02:20 PM   #13
Camper Less Camping
Cajun Po-Boy's Avatar
Yikes...at least you found it before someone became sick from it due to exposure...good luck on the mold remediation.
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 09-07-2014, 02:48 PM   #14
vinmaker's Avatar
You got some work Cory. Good luck and post some of the after pics.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
led, roo, roof
